About to buy front 5100s to level out
Discussion in 'Suspension' started by kulcat, Sep 26, 2011.
  1. Sep 26, 2011 at 7:43 AM
    kulcat
    kulcat [OP] Well-Known Member
    Thomas
    Plano, TX
    Hey guys, just wanted to throw it out there that I'm planning to buy 2 front 5100s from DSM clicked up to 1.5". I'm hoping by doing that, I can achieve that level look with a stock rear. I have NOT done TSB either. I'm also going to replace the stock 265/70/16s with 265/75/16s to give about another .5" so in theory my ultimate goal is to get about 2" of lift from the stock height. I don't wheel, but I do have to use 4x4 in the mud every now and then. I don't really want to go much higher than 2" so I"m thinking i can just leave the rear alone and not order anything for it. Whatcha think? I can't wait to give it a whirl! I'm planing to get the GOODYEAR WRANGLER TDs btw. Thomas PICS ARE HERE....ended up with the DURATRACS in 265/75/16 with front setting at .85" I'll try to take more if I can ever get home from work when it's light out :(
    BEFORE
    AFTER
  2. Sep 26, 2011 at 8:49 AM
    kulcat
    Thomas
    Plano, TX
    Chit....I'll measure tonight and see exactly what I'll need. Maybe I can get away with just .85 on the front and maybe leave a slight rake.
  3. Sep 26, 2011 at 9:13 AM
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    Subbing for pics when done...I also have 265/75/16s and plan on 5100s, so I'm curious to see the results.
  4. Sep 26, 2011 at 8:32 PM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    subbed for pic too. want to get 5100's set to .85..might not get it perfectly level but i dont think the dreaded front end vibes r as likely with .85
  5. Sep 27, 2011 at 8:54 AM
    kulcat
    Thomas
    Plano, TX
    Just purchased all 4 from DSM. Can't wait!
  6. Oct 22, 2011 at 12:01 PM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    Allright sir...where are those pics? : )
  7. Oct 22, 2011 at 10:13 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Here is mine, front at 2.5 and 1" rear block. The truck is on a slight incline, but you get the idea. IMO get a 2" AAL in the rear because it will settle.
  8. Oct 24, 2011 at 8:41 AM
    kulcat
    Thomas
    Plano, TX
    still working on getting them on there :( Having a baby just takes all my time away :) I'm hoping to get'em on soon.
  9. Oct 24, 2011 at 8:47 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    Just purchased my front 5100s from DSM 2 minutes ago. I'm just leaving the stock rears (only 21XXX miles on the truck) w/no TSB and setting them to .85.
    I haven't rubbed yet w/my new tires, but it does look a wee bit tight in the wheel well.
  10. Oct 24, 2011 at 11:33 AM
    kulcat
    Thomas
    Plano, TX
    What size tires are you running with? I also do not have TSB and was going to do .85 in front. I'm going with 265/75/16 once I have the shocks on there.
  11. Oct 24, 2011 at 11:34 AM
    Falcon86
    Falcon86 Well-Known Member
    Virginia Beachshire
    Bone-stock
    I've got the TSB and need 5100's up front badly. Front looks about 3" or so lower right now.
  12. Oct 24, 2011 at 11:41 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    I have 265/75/16...I don't really want/need any overall lift, just trying to give the front a better look and prevent potential rubbing (although I doubt that will be an issue).
    I'm holding off on the rear until they need replacing (I only have 21,xxx miles).
    EDIT: And I think 1.75 would be around level, but it would be too easy to be nose high with any sort of load w/out the AAL.
  13. Oct 24, 2011 at 2:21 PM
    Bolt79
    Bolt79 Well-Known Member
    White Springs, FL
    2022 Lunar Rock Trail Edition
    Screen ProTech kit, JDMCAR center console organizer, JDMCAR Center Console Armrest Cushion, Toyota door sill protectors, Black Toyota tailgate letter inserts
    TSB and 5100's set to 1.75 is the way to go.
  14. Oct 24, 2011 at 2:22 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    if you do not have the TSB 1.75 may be nose high, 0.85 will be better
  15. Oct 24, 2011 at 2:26 PM
    07NavyTaco
    07NavyTaco Well-Known Member
    Josh
    North Chicago
    07 SR5, short bed, 4x4, bilstein 5100s
    billy 5100s @ 1.75, black grill and lower valence, tinted windows
    5100s set at 1.75 and nothing in the rear, no lift or tsb. Sits almost perfectly level, haven't measured but look GREAT and i love it.
  16. Oct 24, 2011 at 2:27 PM
    07NavyTaco
    Josh
    North Chicago
    ^^also running 265/75R16
  17. Oct 24, 2011 at 2:34 PM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    Does it creep up to "nose high" extremely easily (even a light load)?
  18. Oct 24, 2011 at 5:58 PM
    pudge151
    Sean
    Connecticut
    i would think so, i have seen the trucks with billies at 1.75 & TSB look nose high with a few hundred lbs in the back
  19. Oct 24, 2011 at 6:06 PM
    jivewalker
    jivewalker Well-Known Member
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS, 2017 LAND CRUISER
    subbed cause I have the TSB and a slight rake, will do 5100's some time
  20. Oct 24, 2011 at 6:17 PM
    DaveEE
    DaveEE Member
    Dave
    San Diego
    2011 Prerunner
    5100's set at 1.75, rear tsb, debadged, magnaflow catback exhaust, color matched grill and rear bumper, 13" euro antena
    I did the tbs to the rear, set the fronts to 1.75 and I am sitting level and looks good
