-   -   Weird issue (5100 at 0 lower than stock...) (http://www.tacomaworld.com/forum/suspension/179717-weird-issue-5100-0-lower-than-stock.html)
Yoytoda 09-27-2011 11:00 PM
I just installed 5100s set at 0 with 885x coils and 1/4" top plate spacers and only got 2.25" lift in the front. WTF!?!?
I measured the distance between the bottom eyelet on the shock to the spring perch and the 5100 is about .5" lower than my stock shocks...
Anyone else notice this?
Yoytoda 09-27-2011 11:06 PM
Also,
my measurment from the center of the hub to fender is 22.5"
stocks are usually 20-20.5
Yoytoda 09-27-2011 11:24 PM
so i just measured again and
the stock shocks are 8.75" from the top of the spring perch to center of the shock eye.
the 5100s set at 0 are 8" from center of spring to shock eye
so i should be getting at least 3.25" of lift without the top 1/4" spacer.
Anyone have the measurement of the ome shocks?
Yoytoda 09-28-2011 11:21 AM
check out stock vs 5100 set at 0
how can they call 0 as the stock height. .85 should be the "stock setting"
Can someone measure their OME shocks?
http://i784.photobucket.com/albums/y...stockshock.jpg
http://i784.photobucket.com/albums/y...ytoda/5100.jpg
steveni70 09-28-2011 11:42 AM
Aren't the OME coils are supposed to give 1.75" of lift? Add the 0.5" for the spacer and 2.25" sounds right.
Yoytoda 09-28-2011 11:56 AM
lots of people report 3"+ with ome 885s
