-   -   Lifting Question (http://www.tacomaworld.com/forum/suspension/181182-lifting-question.html)
bohunter1990 10-06-2011 06:38 PM
Lifting Question
I am looking for a small lift on my 06' DBL Cab, if I go with a 3" AAL and Billy 5100's in front will I be ok? I am having Cooper AT3 265 70R 16's installed next week and would like to have a little more clearance. Thanks in advance! Joel
KPT 10-06-2011 06:42 PM
3" add a leaf wouod be a bit much IMO. 1.5" in the back will level the truck. 265/70/16s are going to look really small with that liftl
Konaborne 10-06-2011 06:44 PM
I assume you'd be setting the 5100's to 2.5?
even if you do, with 3 in the back your rear will be a good 2+ inches higher in the rear, so it might be a little much.
isnt 265/70r16 stock?
2011TacoBeav 10-06-2011 06:48 PM
Ok. Stock the truck has a nose low rake.
The bisteins 5100s provide a 0-2.5" loft for the front.
A 3" AAL. which I've never heard of would lift it mor than the possible 2.5" in the front.
Mean if you put a 3" AAL in the rear at best you will lift the rear .5" higher than the front.
If you want level the truck go with billies (bilstein) in the front at 2.5" setting if your running stock coils.
Do some research bud, (on here from those with experience), and you will find the key to what you want. :-)
P.S. Everything I just stated is based of my own research... I have ordered but yet to instal my lift. (bilstein 5100 set at .85 with eibach coils, rear 2" AAL with billies)
bohunter1990 10-06-2011 06:50 PM
So maybe go with 2" AAL in the rear? It came stock with 245 75R 16's
2011TacoBeav 10-06-2011 06:51 PM
265 is in fact stock.
I'll be running 265 duratracs with 3" lift up front with 2" aal in rear as I would like to maintain a wright rake and acknowledge my rear will settle more than the front
KPT 10-06-2011 06:51 PM
You can fit bigger than 265/70/16 even without a lift.
OZ-T 10-06-2011 06:52 PM
Get Dakars
2 1/2 - 2 3/4 "
KPT 10-06-2011 06:53 PM
265/70/16 is stock for TRD offroads. Base models come with 245/75/16
2011TacoBeav 10-06-2011 06:56 PM
Originally Posted by OZ-T (Post 3831481)
Get Dakars
2 1/2 - 2 3/4 "
You LOVE your Dakars!! Always posting positive things about them....
Makes me wonder if that's what I should be looking to when my 2" aal settles
2011TacoBeav 10-06-2011 06:59 PM
This is true... Mine came with the 245s.
Will be putting the TRD 16" rims and 265/70/16 fails on for a couple weeks before I put the 265/75/16 duratraks in my 16s
larry2375 10-06-2011 07:02 PM
Truck has 2.5" 5100 plus .25" driver side spacer and 2" aal. Looks pretty level
bohunter1990 10-06-2011 07:06 PM
"P.S. Everything I just stated is based of my own research... I have ordered but yet to instal my lift. (bilstein 5100 set at .85 with eibach coils, rear 2" AAL with billies"
I think this is the right approach for me. Thanks for the advice! I just dont want to have the tires undersized by the lift. P.S. this is my daily driver.
2011TacoBeav 10-06-2011 07:07 PM
What kind of UCA are you running?
KPT 10-06-2011 07:09 PM
They are going to look very undersized. Most people run tires 2" bigger (285/75/16) than that with their 2.5" lifts.
2011TacoBeav 10-06-2011 07:15 PM
Yeah I was worried about my tires being undersized for the lift. In the end it came down to not wanting to trim my brand new Tacoma body parts, fuel economy, and over all look (I didnt want it to look like I stuffed the largest tires possible under my rig. Lol)
Mine will also mostly be a pavement pounder... Maybe 5-10% off road. If I was looking for something more off road capable I'd go with (again based off my research and what guys have said on here) and OME lift as I hear it is a tougher system. It's drawback is a rougher ride...
bohunter1990 10-06-2011 07:21 PM
What size tires are you running Larry?
KPT 10-06-2011 07:23 PM
His profile says 285/70/17, same width and diameter as my previously mentioned 285/75/16.
Konaborne 10-06-2011 07:25 PM
265/75r16 and 285/75r16 are the most popular for lifted trucks
2011TacoBeav 10-06-2011 07:33 PM
So because your lift is 3/4" of an inch lower than the 2.5" cutoff your running 265s?
What made you decide on your lift height and tire size?
