-   -   Another LIFT thread (http://www.tacomaworld.com/forum/suspension/186767-another-lift-thread.html)
jarpil 11-07-2011 07:46 PM
Another LIFT thread
I am sorry for starting another thread like this but after going through all the lift threads on this forum for two days i am confused the same i was before i began reading.
I am thinking about 2-3" lift with 285's Mickey Thompson Baja ATZ tires with 16" wheels. If i do that i want to do it right and have no issues with tire wearing etc.
I was told in our local shop that new rear shocks would be needed as the stock Billsteins wouldn't work. Front shocks would work according to the local shop guy. I was thinking about set of Billstein 5100's for all 4 corners and then i don't know...
Do i need spacers? Do i need to do any trimming? I would appreciate greatly a help in this as i am really confused.
Would Revtek 3" lift http://www.revtek.com/toyotasusp.asp#426 work with stock shocks?
Sublime 11-08-2011 12:11 AM
Nooooo! Revtek is the last thing you want! If you're looking for 2-3" out of those get some eibach coils too! With the 5100's set at .85" you'll have 2-2.5".......or toytec already sells a set for $599 and you can replace them yourself with basic hand tools, no spring compressor needed!
jarpil 11-08-2011 08:17 AM
Ok no spacers then. I am leaning towards 5100's with Eibachs and Toytec AAL(do i need AAL with my suspension TSB?). Should I get 5100's for all 4 corners or just the front and keep stock rear Billsteins?
4Wheelin4Banger 11-08-2011 08:47 AM
It depends how much you want to lift it & if you want to keep factory rake (rear higher). It will ride better with 5100s in the rear also but no it isn' t required. If you get an AAL get the longer 5100s for the rear.
A locals Taco. He has the TSB leafs
Originally Posted by la0d0g (Post 3766802)
Originally Posted by la0d0g (Post 3767803)
The rims are 16x8, 265/75/16 tires, and I have the TSB pack. When we originally put the lift on it looked to lean a little but now I can't really tell. Maybe my driveway is crooked :D but at this time no spacers for lean.
jarpil 11-08-2011 08:05 PM
I have not decided yet but this is what i am thinking about:
Toytec lift kit:http://www.toyteclifts.com/index.php...mart&Itemid=72
I will get Moto Metal 951 16/9 wheels with 285's M. Thompson Baja ATZ tires.
Do i need differential drop kit and new UAC's?
jarpil 11-08-2011 08:42 PM
Originally Posted by 4Wheelin4Banger (Post 3996161)
....If you get an AAL get the longer 5100s for the rear
Are the longer ones included in the kit i mentioned?
4Wheelin4Banger 11-09-2011 12:26 AM
Toytec lift kit:http://www.toyteclifts.com/index.php?page=shop.product_details&flypage=flypag e.tpl&product_id=58894&category_id=113&option=com_ virtuemart&Itemid=72
No on the diff drop.
Debatable on the UCAs. Some say yes, some say no, Some say maybe.
I am runnining stock UCAs and it drives fine with stock 245/75/16s.
I've heard with larger tires they may be nessasary. I'm going to get 265/75/16s and will see what it drives like.
I would ask ToyTec before ordering.
From the Downsouth Motorsports website:
0" to 1.5" Rear Lift on NON-TSB leaf springs, Shock Part #: BE5-C478-T0
Extended Length: 22.94"
Collapsed Length: 14.02"
3" to 4" Rear Lift Shock Part #: BE5-B110-T5
Extended Length: 27.28"
Collapsed Length: 16.34"
Sublime 11-09-2011 03:30 AM
With a 2" rear lift the longer ones will be cutting it close. The compressed length may be an issue.
4Wheelin4Banger 11-09-2011 07:52 AM
He's talking TSB leaf pack & AAL. I think the TSB leafs add 1 1/2" and the TSB AAL is 1 1/2" for a total 3" lift.
04LTtacoma 11-09-2011 07:55 AM
Your not sorry dammit! lol jk jk I would suggest the toytec lift or OME lift.:)
jarpil 11-15-2011 09:09 PM
4 Attachment(s)
Still have not decided what to do yet.... :( Put new wheels on with AT 265's BFGoodrich tires. Now i am thinking about the lift. Got an estimate for OME lift from a local 4wd shop. They want $450 just to install the lift which i think is little too steep.
Sublime 11-15-2011 11:36 PM
Just get 5100's all around and set the front at 1.75" w/ 1.5" aal. Don't get the longer rear shock because the tsb only adds 1/2" I believe.
Edit - OME is a good choice too! Your prob looking at 4hrs of work for a shop to do either setup!
4Wheelin4Banger 11-16-2011 07:35 AM
It's not hard to install a lift. Another TW member and I did two complete lifts in under 4 hours with some help from my wife.
OZ-T 11-16-2011 08:21 AM
$450 doesn't seem that steep for 4 hours of shop time
NC15TRD 11-16-2011 11:07 AM
Maybe not it canadian dollars!
OZ-T 11-16-2011 11:10 AM
The dollar is at par !!!!
How much is a shop rate down there ?
jarpil 11-16-2011 01:29 PM
The quote is for 6 hrs at $75/hr. Also the OME kit he is selling is 100 bucks more then i can get it online + $52 freight which is ok.
richardbui23 11-16-2011 01:34 PM
she sounds like a keeper.:cool:
