2 Leaf Springs?!
Discussion in 'Suspension' started by petezny, Nov 10, 2011.
  1. Nov 10, 2011 at 10:03 PM
    petezny
    petezny [OP] Active Member
    Pete
    Long Island
    11 Standard Cab 4cyl 4WD
    I have two leaf rear springs is that normal?
    2011 Taco standard cab, 4wd, 4 cyl, auto.
    I have been lurking around the suspension forum reading everything I can and complaining about my tacos inability to carry anything heavy without the springs going in an reverse arch. I researched every load booster (bags, aal, assist springs etc) and finally decided decided on an add a leaf from Toytec. The only thing I needed to check before I ordered was if I had a three leaf or four leaf spring pack. So imagine my surprise when I went under the truck and saw that I have only two leafs in each spring! Is this normal? Are they really serious with this spring, no wonder this truck can't carry a serious load. So the question is do certain models like mine have only a two leaf spring while others have three or four or is something wrong here?
  2. Nov 10, 2011 at 11:23 PM
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    It should be 2 leaves with a thicker overload on the bottom. If there is no overload you have some frankenstein springs.
  3. Nov 10, 2011 at 11:25 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    2 leafs plus the overload is the 3 leaf or US stock pack
    3 leafs plus the overload is the 4 leaf ( TSB ) or Canadian stock pack
  4. Nov 11, 2011 at 7:14 AM
    petezny
    Pete
    Long Island
    Ok thanks guys I wasn't counting the overload, I never have in the past. So then the normal spring pack is only two load carrying leafs then the overload. All the pics I have seen here and at Toytec have shown 3 load carrying leafs plus the overload so those were the 4 leaf TSB springs then?
    Thanks again unfortunately the TSB doesn't cover my truck, standard cab, so I guess my only path is the add a leaf.
  5. Nov 12, 2011 at 8:24 AM
    petezny
    Pete
    Long Island
    As a quick post script at the store today I peaked under some other late model Tacos to see what they had. They were all Access cabs and all had the same spring pack I have in my standard cab. One had a cap on and was riding low in the rear, guess he doesn't know about the TSB. I should have just looked under some other trucks in advance and have skipped this whole thread.
    Thanks again
  6. Jan 4, 2012 at 8:28 AM
    Moshenek
    Moshenek Member
    Michael
    Norfolk
    05 TRD DCSB
    So if my truck has 4 leafs total I'm either missing the TSB or the AAL that was supposed to be installed before I purchased the truck. Is there anyway to tell which is which? What are the dems for the TSB?
  7. Jan 4, 2012 at 12:45 PM
    Moshenek
    Moshenek Member
    Michael
    Norfolk
    05 TRD DCSB
    Or could I simply add another AAL either way and be done with it? My truck is nearly level if not raking back
  8. Jan 4, 2012 at 12:52 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    1. Start your own thread. This thread belongs to Petezny.
    2. Work on your reading comprehension.
  9. Jan 4, 2012 at 1:00 PM
    jflan
    Vancouver, WA
    Yes, 2+1 configuration on US 2nd gen Tacos. Been going on since the beginning because Toyota determined that most of us haul "air".
    They could be TSB or aftermarket.
    Check your VIN against the TSB.
    Some have been successful with the TSB for single cabs.
