Can you combine a 3" lift kit with a 6" to get 9" total?
Discussion in 'Suspension' started by XBobbyX, Nov 12, 2008.
  1. Nov 12, 2008 at 12:26 PM
    XBobbyX
    XBobbyX [OP] New Member
    Denver
    '19 TRD OFFROAD
    This may seem like a stupid question but.... Is it possible to add a 6" suspension lift to the 3" I already have? or do i have to take the 3" out and just install a 6" and then get a 3" body lift?
  2. Nov 12, 2008 at 12:30 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
  3. Nov 12, 2008 at 1:06 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Im pretty sure that "gotlift" does not have a body lift.
    And it all depends on what kind of lift you will be doing. for the rear you could do AAL and blocks... as for the front im not sure
  4. Nov 12, 2008 at 1:22 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    yeah, gotlift has 9" of suspension....not sure exacty how, but something to do w/ like 6" blocks in the back or something. most w/ 9" go for a 6" suspension and a 3" body
  5. Nov 12, 2008 at 1:39 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I didn't mean that Gotlifts had body lift, was just giving a reference to how high 9" is. Sorry that wasn't clear. He actually uses his truck thus giving an opinion on how it drives.
  6. Nov 13, 2008 at 8:07 AM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    u can. the 6 " lowers all the front end to factory specs so when u are done it maintains factory angles just 6" higher. so puting a 3" lift on it is like puting it on a stock truck. However make sure u use a 6" lift with new front coilovers not spacers if u want to do this. like the stage 2 fabtech or procomp kits they come with longer front adjustable coilovers. u dont want to put an extra 3" on a 6" kit that uses the spacer upfront. never stack spacers. another option is to just get the 6" kit with the new coilovers and crankem up a couple inches i wouldnt go 3" more like 2" would be better. but it is another option..
  7. Nov 13, 2008 at 8:16 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    BassAckwards likes this.
  8. Nov 13, 2008 at 8:22 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    ^^^IMO that truck looks stupid. I do agree with allrsdup on the lift though.
  9. Feb 19, 2010 at 7:51 AM
    yotabeast505
    yotabeast505 The Beast
    David
    NE Hights ABQ NM
    THE BEAST
    here we go. Ford 9" rear after breaking 5 sets of gears in the stock yota 8.8, 5.13 gears with a detroit hard locker, 63" chevy leafs and custom hangers, sky's front spring hanger with sky's extream hysteer and PSC hydro assist ram and PSC pump. welded front spyders in the f-550 front dana 60 with warn hubs, pico brake lines and hoses, elecrtic fan, TRD supercharger with URD 2.1 Pully, URD Map-ECU2 and cage built by me. wide band a/f by inovations, lots and lots more...........
    DO NOT STACK SPACERS!!! and if your offroading ur truck DO NOT USE BLOCKS IN THE REAR . #1 stacking spacers on the front struts will BREAK UR CV shafts like they were mad out of wood trust me autozone hated me for life time cv shafts lol and truck wont articulate at all... lots of stress on the strut buckets... #2 blocks in rear is STUPID!!! wheel hop can and will happin due to pivot point of spring and axle seperated can also shatter pinion gears.... and finaly the driveshaft angle will be out of wack unless shimmed but shims with blocks very bad combo!!! check out the blocks and steering on some of these trucks lol http://128.83.80.193/scarysteering/index.html
  10. Feb 19, 2010 at 7:56 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
  11. Feb 19, 2010 at 9:01 AM
    mylittletacoma
    mylittletacoma taco? like the kind you eat?
    Las Cruces, NM
    00 Silver SR5 4X4 SC
    TRD Supercharger, URD 7th injector kit, Gibson Exhaust, Deckplate Mod, Tough Country 5" lift kit, Fabtech coilovers, Daystar 1" bodylift, 35" Kumho Road Venture MT's mounted on Eagle Alloy 185's black 15x8 -12offset, Alpine 9883 deck, Alpine type R speakers all around, Alpine 500w amp to 10"Boston G1 in custom built rear center console enclosure
    AGREED W/ YOTA BEAST505, If you want to go higher than 6" then do a body lift on top of a 6 inch suspension lift. I personally have a daystar 1" body so the frame doesnt show all stupid like, and i am running the Fabtech 3.5" coilover system with 2.5" AAL in the back. I am preparing to install the TUFF COUNTRY 5" suspension lift and putting 3" shackles instead of using the blocks. so all together i will be sitting at 6.5 in the back and when i adjust the coilovers i will go to 7" in the front.
    thing is 3" is the maximum for lift in the front due to UCA issues and if your a 4x4 the angle of the front cv shafts. so if you have a 3" coil lift then you put the 6" sus. your still gonna have alignment issues and cv shaft problems.
    just my 2cents that i have learned from the Taco Gods on here like Chris4x4
  12. Feb 19, 2010 at 10:36 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    ditch the drop bracket and body lift idea... SOLID AXLE that truck...
    if you really want to go that high, do it right and make it a chick magnet at the same time...
    you will be able to actually wheel the piss out of the truck offroad and at the mall...
    Pep's truck...
  13. Feb 19, 2010 at 10:38 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    or even better, Yotabeast505...
  14. Feb 19, 2010 at 10:42 AM
    Gr8WhiteTaco
    Gr8WhiteTaco bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    That truck is in the running to be in TTC. Yotabeast505, you should apply to be in it!!1
  15. Feb 19, 2010 at 11:38 AM
    yotabeast505
    David
    NE Hights ABQ NM
    THE BEAST
    in the TTC huh? have no clue what that is but looks like the TOP TRUCK CHALANGE OR THE TOYOTA TRUCK CHALANGE LOL witch is it and were do i apply lol
  16. Feb 22, 2010 at 4:27 PM
    mylittletacoma
    Las Cruces, NM
    I like those, but personally, i think they are not the best suited for a daily driven fun vehicle, if your a hardcore wheeler and it never sees the streets except for if you have to drive it to the mud pit then thats great, but for practicallity,,, which i think he is asking about, i dont think solid axle would be good.... do you?
  17. May 26, 2010 at 1:45 AM
    Carolina_Boy
    Carolina_Boy Carolina_Boy
    Brandon
    Columbia South Carolina
    2009 Tacoma TRD SR5
    6'' fab tech performance suspension lift, 35-1250-18 Nitto Mud Grappler Extream terrains, XD Monster 18'' matte black rims, Relentless Fabrication Front Bumper and Rear bumper with a Ramsey 9000 mounted in front bumper.
    ok so i have a 3 inch lift lever kit and running 33 inch nitto mud grapplers extream terrain. i want to gain an extra 2-3 inches without a body lift wanna stay with my suspension what is the best way to do it const effective. i.e. use the 5100 shocks and strusts extended out to its max with my spacer or what. any idea would be greatly appreciated
  18. May 26, 2010 at 6:19 AM
    TexasTacoma37
    ^^^You can't use the 5100's and the spacer at the same time. That's stacking lifts and is nooooo good.
  19. May 26, 2010 at 7:28 AM
    TexasTacoma37
    I just realized you've posted this question in 3 separate threads. Each time you got the answer that you cannot do this.
    What more do you want from us? No one is going to tell you it's a good idea. The shocks will top out and have no downward travel.
  20. Dec 16, 2010 at 2:43 AM
    skyedtacoma808
    skyedtacoma808 Member
    97 tacoma
    6" fabtech suspension, 3" body lift, 33 by 14.5 trexus, headers
    Would I beable to put a set of toytec coils on a trailmaster sus lift instead of with the fabtech?
