-   -   3'' lift question (http://www.tacomaworld.com/forum/suspension/189521-3-lift-question.html)
BackwoodsTaco 11-23-2011 09:29 PM
3'' lift question
1 Attachment(s)
Hello everyone, I just bought my first Tacoma about a month ago :D and I absolutely love it but now I'm ready to lift it so I'm getting the Revtek 3'' lift and the website says i can fit 33's but i just wanted to make sure before i buy the tires that they will fit. If 33's won't fit then would you please tell me the biggest size i can run. btw they will be mounted on my stock 16's till i can find some i like, Thanks
Here are some pictures of my baby the day i got her
http://i1223.photobucket.com/albums/...er02/Taco1.jpg
http://i1223.photobucket.com/albums/...er02/Taco4.jpg
http://i1223.photobucket.com/albums/...er02/Taco3.jpg
http://www.facebook.com/photo.php?fb...type=3&theater
Maverick904 11-23-2011 09:33 PM
First off Welcome to TW.
Click the link regarding suspensions in my signature, great great info there. Im pretty sure the revtek lift is a spacer lift if I remember correctly and most people shy away from those.
There are some other ways to get the lift wanted without breaking the bank and not getting poor quality if you have not already bought the lift.
Im not sure on tire sizes on first gens but somebody should chime in soon.
Snowman 11-23-2011 09:46 PM
33's will probably rub the frame no matter what lift, mine do with 3" lift. I had to grind down the pinch weld too.
Might depend on the 33's though. Mine are 285/75/16s but a 255/85/16 is a fair amount narrower so they might not touch the frame, but they are also slightly taller.
I just ordered a new set of tires and went with 265/75/16s (32's) because I was annoyed by the rubbing and didnt want to go the spacer route for legal reasons.
BackwoodsTaco 11-23-2011 10:02 PM
Thank you both the revtek kit is a spacer kit with blocks in the rear. it's not going to be up there long, just till summer, I'm gonna do a 6'' lift with 35's. just want some that will let me do some mild off-roading and get me around on the farm.
Snowman 11-23-2011 10:06 PM
You should probably float around the 1st gen section of this forum before buying any spacers/blocks and research long and hard before trying to make a 6" lift. Most around here agree that a 6" lift on a 4x4 cannot be done properly unless you SAS the truck, which is big $$$.
You would be better off staying stock than adding spacers and blocks if you want to offroad even a little. They will cause more damage in the long run.
BackwoodsTaco 11-23-2011 10:18 PM
All right thanks buddy I'll check on that
