5100's Riding terrible (help)!!
Discussion in 'Suspension' started by Cajun1, Dec 12, 2011.
  1. Dec 12, 2011 at 9:13 PM
    Cajun1
    Cajun1 [OP] Well-Known Member
    Brooks
    Abbeville, LA
    Brush Gaurd 265 Destinations 5100's @ 1.75 LED Lighting Center console Home made Saatchi DDM 5K HID
    I have recently replaced my Coil over spacers with 5100 set at 1.75" and i find that the ride has stiffened up tremendously. Which i do not like...so after doing research on TW i found that preloading my springs is the reason for the stiff ride!!! So my Alternative is to get new Spring. I was thinking about the OME 885 so that i can still get 2in of lift with my 5100 set to 0...
    First of all would this be a solution to my stiff ride?
    Or should i go with OME 884 or Eibach springs?
  2. Dec 12, 2011 at 9:16 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    you would have more than 2 inches of lift with the new coils
  3. Dec 12, 2011 at 9:22 PM
    TACOMABOSS
    96 SR5 4x4
    really? only 1.5-2" for second gens?
  4. Dec 12, 2011 at 9:23 PM
    acdronin
    acdronin Well-Known Member
    Do you still have stock coils and were you replacing stock shocks? If so then yeah your ride stiffened up, 885's will probably make it stiffer.
  5. Dec 12, 2011 at 9:30 PM
    acdronin
    I replaced my stock shocks with 5100's (kept the same springs), and noticed the ride was stiffer, but it also took away the sickening body roll in the front, fair trade i say
  6. Dec 12, 2011 at 9:33 PM
    Cajun1
    Brooks
    Abbeville, LA
    It's an SR5
    I dont have a picture but i read a thread on here were that guy put them upside down and im positive i didnt, I did it just like the stock shocks were facing... and i do have stock coils...the ride is almost 50% stiffer than what my spacers offered!!
  7. Dec 12, 2011 at 9:35 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    LED Headlights, Volant CAI, 32" Duratracs
    What spacers did you have on there before? Revtek? Toytec? Were the spacers on the top plate or on the coil?
  8. Dec 12, 2011 at 9:38 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    So you've arrived at a predictable result.
    In your first set up your springs were not preloaded. Now they are preloaded.
    And if your springs are a progressive type, you may have blown through the 1st stage with the preload which would further degrade ride quality.
  9. Dec 12, 2011 at 9:42 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    FYI , I got 2 1/2" of lift from my 885's on my DCLB 4x4
  10. Dec 12, 2011 at 9:42 PM
    Cajun1
    Brooks
    Abbeville, LA
    would u say with the Eribach and 5100s at 0 it is about stock ride quality?
  11. Dec 12, 2011 at 9:46 PM
    Cajun1
    Brooks
    Abbeville, LA
    or should i just set 5100's at 0'' with stock coils an put the spacers back..(which i dont really want to use spacers b/c the Negative things i've been reading on TW about spacers)
    never the less my main goal is to be (level/little bit nose high) with a very good ride quality due to every road in Louisiana being absolutely horrible!!!!
  12. Dec 12, 2011 at 9:48 PM
    jflan
    Vancouver, WA
    Someone that knows the exact spring ratings please chime in, I'm going to guess.
    stock spring = 550#
    885________= 590 #
    Eibach_____= 620#
  13. Dec 12, 2011 at 9:48 PM
    Cajun1
    Brooks
    Abbeville, LA
    well having you said that....i think this might be my next buy...Eibach...thanks
    oh an i just went take a picture of my perch but dont know how to post it...but just for shits an giggles i wanted you to look to make sure i did them right
  14. Dec 12, 2011 at 9:49 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
  15. Dec 12, 2011 at 9:49 PM
    Cajun1
    Brooks
    Abbeville, LA
    not too sure that those numbers mean!
  16. Dec 12, 2011 at 9:53 PM
    Cajun1
    Brooks
    Abbeville, LA
  17. Dec 12, 2011 at 9:53 PM
    Cajun1
    Brooks
    Abbeville, LA
    are they correct?
  18. Dec 12, 2011 at 9:57 PM
    Cajun1
    Brooks
    Abbeville, LA
    so would a spring rate of a higher value yeild a smoother ride?? or a Lesser value?
  19. Dec 12, 2011 at 9:59 PM
    jflan
    Vancouver, WA
    OK, I'll change that, thanks.
  20. Dec 12, 2011 at 10:00 PM
    Cajun1
    Brooks
    Abbeville, LA
    are the perch the right way?
