-   -   Is this kit any good? 6 inch Lift Kit with ES3000 Shocks (http://www.tacomaworld.com/forum/suspension/199347-kit-any-good-6-inch-lift-kit-es3000-shocks.html)
Brian1441 01-19-2012 04:27 AM
Was thinking about getting the pro comp 6" lift kit was trying to see if it is any good.
This is what it comes with
Lift Height: 6 Inches
Front Lift: Front/Rear Crossmembers
Compression Struts
Spindles
Front Sway Bar Spacers
Bump Stop Extensions
Steering Correction: Brake Line Extension Brackets
Rear Lift: Block/U-Bolt Kit
Shocks: Rear ES9000 Shocks
Shock Boots Included
Max Tire Size: 35X12.50
Wheel Size Range (Inches):17-20
Wheel Width Range (Inches):8-9
Min-Max Backspace (Inches)4.0-4.65
93civEJ1 01-19-2012 08:04 AM
I have this kit and love it. It was a fairly straight forward install.
COMAtose HI 01-23-2012 06:10 AM
im installing the exact same kit on my 2012 today. ill let you know how it turns out.
Brian1441 01-24-2012 11:38 AM
Ok cool thanks because I wasn't sure if I should try and save up the extra grand to get coil overs . And if you get a second do you think you might be able to post some pictures.
COMAtose HI 01-24-2012 12:00 PM
i should be done with the installation by tomorrow. ill try and get some pictures up tomorrow night.
bigdaddytaco 01-25-2012 08:54 AM
i wont to see some pix of this lift
COMAtose HI 01-25-2012 08:57 AM
hey guys sorry for the wait...i'm not sure if you read it in the other threads, but 4WPs screwed up on my tire and wheel order. Due to my work schedule, I won't be able to pick up my truck until Saturday. I'll get some pictures up ASAP.
