How far does the Taco lean?
Discussion in 'Suspension' started by rblloyd, Dec 3, 2008.
  1. Dec 3, 2008 at 7:17 AM
    rblloyd
    rblloyd [OP] Member
    1999 2.7L SR5 Tacoma 4x4
    I recently bought a set of leaf spring packs from wheelers for my 2000 Extended Cab 2.7 4X4. I bought the 5 leaf packs that are meant to allow more cargo capacity and about 1.5" more ride heigth. I also bought some OME coils for up front to level it out! So I love the way it sits now but I cant help but notice that the drivers side of the bed still seems to "lean" quite noticably. Every once in a while I will park in a spot that seems to help it but most of the time it just looks like its low on that side. When I bought the leafs, wheelers told me that the drivers side leafs were made to be a bit stiffer to help with the problem. Could there be something else going on under there? Thanks, Im new to TacomaWorld and I love it!
  2. Dec 3, 2008 at 1:39 PM
    josh3972000
    josh3972000 Well-Known Member
    kentucky
    02 dbl cab TRD
    Sounds like you have the same problem many of the members have, the "Tacoma Lean" Im sure some of the other members will chime in soon, I would help out but Im not very good on that issue. Its nothing to worry about alot of people have this problem. If I remember correctly someone had a previous post on correcting this.
  3. Dec 3, 2008 at 7:16 PM
    rblloyd
    rblloyd [OP] Member
    I would love to hear about what could be done to correct it! Or if there were any hints as to what more it could be.. I always just thought that the OEM leaf packs were weak, but with new leaf packs I dont know!
  4. Dec 27, 2008 at 6:31 PM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    I had the suspension TSB done on my 08 with the front Bilstein 5100s set at 1.75". The P-side is about a 1/2" higher than the D-side (front and rear). This is driving me Fing nuts and it really sucks 'cause I didn't take any measurements prior to getting any of the suspension work done.
  5. Dec 27, 2008 at 6:36 PM
    Cobra69
    Cobra69 Well-Known Member
    Taxachusetts (Massachusetts)
    02 Tocoma TRD Expedition Setup
    2002 Tacoma TRD Access Cab, Deckplate Mod.,Grey wire Mod.,Cobra CB,Ext. Diff. Breather,E-locker rear only for now,CBI Custom Winch bumper, SAW 2.0, All Pro 5" leaf packs+Bilstiens 5150-10" shocks,Cooper STT 285x75x16 on Wheelers Type B 16x8 rims, Budbuilt front+Mid skid plates, Custom transfer crossmember+skidplate,Trail-Gear sliders,custom roof-rack,Ultimate-air CO2 tank,4-Hella 500 H.I.D. Lights,Atlas 10,000 lbs winch. Custom Half-doors for the summer.
    It leans on the driver side due to the extra weight..........gas tank. Fill it up and look at it I bet it leans more full then empty. Plus the driver side always has weight in it going down the road.........YOU........so the springs on that side settle a tad bit more.
    You can add a slight spacer to your cols to help correct it. I just adjusted my CO's so as they would even out.
  6. Dec 27, 2008 at 6:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i have the same setup on my 04 dc.........ome coils up front...wheelers 5 leaf packs out back. mine doesnt have any lean to it yet...........but for you, you can always get a top plate spacer(1/4) from toytec and install it. it should help correct the lean...or get a trim packer for the driver side. you can get it from wheelers or toytec for pretty cheap and it will help correct the lean problem you are having.
  7. Dec 27, 2008 at 7:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2 on what Will said. I went so far as to have an AAL made for my truck and I had a little more arch added to the diver side spring. My truck is within 1/4" on all sides, with a full tank. :)
  8. Dec 27, 2008 at 7:13 PM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    I make a ton of steel blocks for the street guys to cure this, they are offset. You could use a solid piece of 1/2" material and bolt it to the bottom of the pack on the low side using a longer center pin, it will never want to come out this way.
  9. Dec 27, 2008 at 7:26 PM
    grivera
    Hanover, MD
    If I add spacer(s) to the D-side to correct this, will i need to re-align?
  10. Dec 27, 2008 at 8:38 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    nah, i see no need for a realignment. i dont think it will make anything go out of adjustment............you just mount the spacer under the top of the coil.
  11. Dec 28, 2008 at 6:05 AM
    grivera
    Hanover, MD
    So I have to disassemble the coil assembly for this?
  12. Dec 28, 2008 at 7:25 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no.....you arent gonna disassemble the coil.....you are gonna take the coil assy loose from the 3 studs on top and the bottom bolt so that you can get the spacer in there. the trim packer/spacer may come with longer studs for you to use, although it may not be necessary. but you will not have to disassemble the coil assembly.
