Toytec 3" lift
Discussion in 'Suspension' started by Sjoffroad, Mar 4, 2012.
  1. Mar 4, 2012 at 11:16 AM
    Sjoffroad
    Sjoffroad [OP] Well-Known Member
    Bay area
    blk offroad pre runner
    Hi all, sorry im new to lifts and stuff like this. So after reading all the info on the ome and bilsteins I decided I wanted to go with the adjustable billies.
    On the toytec site, there are two sets of billies sets. One is for $629 and the other for $899. After reading all about them I guess the main difference is one of the kits the front coilovers comes fully assembled plus has a rear block kit, rear axle degree shims for proper pinion angle alignment, and u bolts. Not sure if the rear shocks the same.
    I don't really care about the front coils not being put together, I can use my stock one correct? My question is, are all the extra parts and different shocks for the rear really necessary? I'm 90% on the road and 10% offroad and even then it isn't anything too serious? I just want the closest ride to stock with a lil lift so I can stuff in more agressive tires.
  2. Mar 4, 2012 at 11:30 AM
    Ryan07
    Ryan07 Well-Known Member
    New Brunswick
    07 TRD DC,LB Sport 4x4
    Icon Ext. Coilovers, LR UCA's, Icon AAL, Nitro 9000 Shocks, 7"Kragen HID's/Billet Grille, Extang Solid Fold Tonneau Cover, Bed Lights, Diff Breather Mod, D-Rings Mod, LED Interior Lighting/Plate Lights, LED 4X4 Switch, Viper Starter, AVH-P4200DVD, PAC Interface, OEM Backup Camera/Pop&lock, Wet Okole Seat Covers, Weathertech Mats, Husky Mud Flaps, 8000lbs Champion Winch/Winch Cradle and Quick Connect Kit, 4,500lbs Champion Winch/Front Hidden Winch Mount, OEM Painted Rims, Spidertrax 1.25, 265/70R17 BFG KO's
    Go with the Bilstein Adjustable lift kit with 5100 shocks or the OME Suspension lift kit. Add-a-leafs no blocks.
  3. Mar 4, 2012 at 11:34 AM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    Using Bilstein shocks instead of your stock shocks is going to give you a better ride quality. And like Ryan said, you are going to want an AAL (add-a-leaf) instead of a block in the rear.
  4. Mar 4, 2012 at 11:50 AM
    Ryan07
    New Brunswick
    Just seen you are a prerunner so I would go spindles.
  5. Mar 4, 2012 at 11:52 AM
    T-Rex266
    T-Rex266 Elon Musk Moderator
    5100s all around
    OLD MAN EMU's
    Add a leaf
    /threads :)
  6. Mar 4, 2012 at 12:30 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    I think I read somewhere that the OME coils with 5100's don't fit properly? I am sure other people run that exact setup but this is just for future reference.
  7. Mar 4, 2012 at 12:31 PM
    T-Rex266
    Use a compressor? I have no problems
  8. Mar 4, 2012 at 12:34 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    I am talking about the coil fitting properly to the "plate" that can adjust with the snap ring on the 5100's. I think I read that the OME coils are too thick (?) to fit on that plate securely. Maybe I am wrong just curious.
  9. Mar 4, 2012 at 1:10 PM
    Sjoffroad
    Bay area
    Yea I heard of that. Don't know too much about it. Maybe I'll look into to it before pulling the trigger on a set up. Do u need new shocks and all that with spindles? Who's makes spindle lifts?
  10. Mar 4, 2012 at 1:28 PM
    Ryan07
    New Brunswick
  11. Mar 4, 2012 at 1:41 PM
    T-Rex266
    No on new shocks. I ordered some b/c it can save some expensive parts from snapping while wheeling.
  12. Mar 4, 2012 at 5:28 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    They are basically the same but the $629 does not have a height adjustable collar at the bottom. They are pre set at 3" and ready to bolt on. For $899 there are better coilovers out there. You'll love the ride from the 5100/eibach set up. Spindles are the better way to lift the front on 2wd but you'll need to also lift the rear as they provide 3.5-4" lift depending on brand. I'd read around a little more!
  13. Mar 5, 2012 at 7:07 AM
    Sjoffroad
    Bay area
  14. Mar 5, 2012 at 7:33 AM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    I have the 3 inch Toyotec with the Billies for $625 I am happy with it.
