New tires + stock 04 DC = rubbing. Need advice
Discussion in 'Suspension' started by mjhenks, Mar 6, 2012.
  1. Mar 6, 2012 at 7:25 AM
    mjhenks
    mjhenks [OP] Well-Known Member
    So.Cal
    04 Jade Green TRD V6 DC
    I need a small lift to clear my new tires. Need some advice as I want to make sure i do this only once.
    Details: New 265/75/16 tires on a stock 04 Double cab. Had worn Remington's when truck was purchased and now have new Rugged Terrain. Both were same size. American Racing Outlaw II rims.
    Rear springs replaced ~ 1 year ago with 4 leaf replacements for axle wrap/sagging. Front is stock.
    The "Rub": The tires slightly rub at the rear inner fender when turning. If I turn and hit a bump then they really rub. Loud.
    I am not looking for a major lift. Just enough to clear the tires.
    I think a minor spacer up front will work but how do you tell how much?
    I will add the same spacers to the rear.
    I did some searching but probably not long enough to find the answer.
    Thank you.
  2. Mar 6, 2012 at 7:45 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    A lot guys here run 265 and don't rub you sure it's not Hitting some thing else
  3. Mar 6, 2012 at 7:50 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    5100s up front set at .85 will level you perfect! Easy fix though....just trim where its left marks and they wont run anymore!
  4. Mar 6, 2012 at 7:50 AM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Have any pictures of where its rubbing at?
  5. Mar 6, 2012 at 5:02 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I run 265/75/16s as well on my stock DC and I don't rub on the fender. I did temporarily, but that was when I found a screw that was holding the fender well lining in was loose. However, it does rub the frame just barely when fully locked.
  6. Mar 6, 2012 at 6:19 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Its the "75" that's making it wider?? 5100s and trimming.....the 5100s will be a vast improvement over stock anyhow, front and rear!
  7. Mar 6, 2012 at 7:31 PM
    ffirg
    mike
    Anchorage, Alaska
    265/75/16 is just over an inch larger in diameter. 30.61'' vs. 31.65''. The width should stay the same.
  8. Mar 6, 2012 at 8:41 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    OK, stock 2nd Gen TRD is 265/70/16...so I was thinking the 75 was. 5" wider??
    My buddy at work runs that size tire on a 1st gen and rubs...I told him to trim and the front end is sagging so the 5100 will stiffen that up!
  9. Mar 6, 2012 at 9:36 PM
    ffirg
    mike
    Anchorage, Alaska
    Ah, gotcha. Yeah, 5100s should help alleviate it. My coils are terribly saggy so that does not help at all. That's why I'm saving for a full OME setup :spy:
