Ruined Dakar rear leaf?
Discussion in 'Suspension' started by asolo, Mar 7, 2012.
  1. Mar 7, 2012 at 6:48 AM
    asolo
    asolo [OP] Well-Known Member
    Arkansas
    DC,LB, 4x4 TRD sport
    OME lift with Dakars in the rear, 265/70 R17 BFG KO2. Interior Light Mod, Fog light Mod, Hella Supertones, WeatherTech digital floormats, TRD front tow hook, trimmed front mud flaps, Demello Bolt-on hybrid sliders. Rigid SR-10 hyperspot in the hood scoop, Baja Deisgns Squadron Pros, 30” Baja Designs ONX6+
    So, I happen to be in Dallas and got a good deal on a OME suspension. I loaded it all in the rental and THOUGHT everything looked good. Upon examining one of the rear dakar leafs when I got home I found this:
    the other side which is normal
    I'm so hacked I didn't see this when I picked it up from 4wheelparts. So, should I attempt an exchange or do you think it's okay? I live 350 mi away from the store I picked it up from.
  2. Mar 7, 2012 at 6:51 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Or tell them you need some money back....
  3. Mar 7, 2012 at 6:51 AM
    98tacoma27
    Ben
    Not Beech Creek
    Your call on returning it. It looks like the rivet is loose. Or is it a bolt?
  4. Mar 7, 2012 at 7:00 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    That's not ruined! Are you kidding me?
    Bend it back to where it was or say fuck it and use it how it is. When it's installed it won't even matter.
  5. Mar 7, 2012 at 7:04 AM
    asolo
    Arkansas
    yeah, it's a rivet. I wouldnt think it would make much of a difference but thought I would ask.
  6. Mar 7, 2012 at 7:06 AM
    asolo
    Arkansas
    It's not loose at all. Just bent.
  7. Mar 7, 2012 at 7:14 AM
    98tacoma27
    Ben
    Not Beech Creek
    Like Josh said, I'd bend it back. It's not worth the hassle driving back IMHO.
  8. Mar 7, 2012 at 10:03 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Bend it back, or grind the rivet off and just remove it all together.
  9. Mar 7, 2012 at 10:37 AM
    asolo
    Arkansas
    Thanks guys. I'll pound it back with a block and sledge.
  10. Mar 7, 2012 at 10:46 AM
    98tacoma27
    Ben
    Not Beech Creek
    Beat it like it owes you money!!!
  11. Mar 7, 2012 at 11:01 AM
    asolo
    Arkansas
    lol. THAT I can do.
  12. Mar 7, 2012 at 11:09 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Beat it like a rented mule .
  13. Mar 7, 2012 at 11:15 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Beat it like a red-headed stepchild.
  14. Mar 7, 2012 at 11:27 AM
    asolo
    Arkansas
    You guys are crackin me up! Can't wait to get it installed. Seems like it's been ages since i posted my first question about the OME lift on TW
  15. Mar 7, 2012 at 11:29 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    as long as the center pin is tight and the ubolts are torqued right, those springs are fine.
    You wanna see a set of ruined leaf springs?:
  16. Mar 7, 2012 at 1:17 PM
    asolo
    Arkansas
    Hey Oz, On a different note: Did you install the CB drop as well as the 3 deg axle shims? I'm trying to figure out the best way to avoid vibes when I install this lift kit. How about the Diff drop?
  17. Mar 7, 2012 at 1:21 PM
    OZ-T
    Peter North
    British Columbia
    I did the OME CB drop , no shims and no diff drop
    I have a slight vibe at 40-45 mph I'm still working on
  18. Mar 7, 2012 at 1:23 PM
    asolo
    Arkansas
    Thanks.
  19. Mar 9, 2012 at 5:37 AM
    Pugga
    Massachusetts
    Did you drive for a while before doing the CB drop or did you put it on when you did everything else? Just wondering if you had vibes then decided on adding it.
  20. Mar 9, 2012 at 7:26 AM
    OZ-T
    Peter North
    British Columbia
    Added it with the lift
