-   -   all pro expo's with OME N182's? (http://www.tacomaworld.com/forum/suspension/208766-all-pro-expos-ome-n182s.html)
Toy Yoda 03-08-2012 12:07 PM
title says it all, can you run OME N182 rear shocks with the all pro expo 3" leaf packs without bottoming out the shocks? i already have the n182's and am leaning towards all pro now instead of the dakars
MJonAgs32 03-12-2012 10:49 PM
also interested
Toy Yoda 03-12-2012 10:53 PM
bump!
MJonAgs32 03-12-2012 10:58 PM
Actually, I think it'll work. Wheelers says the N182s are 13" and AP says any 10" shock will work with the expos
Toy Yoda 03-12-2012 10:59 PM
Originally Posted by Idaholandho (Post 4728359)
Can you possibly contact All Pro for the answer?
stop makin so much sense!:rolleyes:
Sublime 03-12-2012 11:15 PM
13"? Damn! Measure them unbolted at the bottom for extended length and measure how much shaft is left for compression. I've seen the AP standards flex to 26.5" assuming most leaf with bumps compress to 16" that's 10" of travel. The main issue you'd have is the bump/compression travel!
MJonAgs32 03-12-2012 11:25 PM
I don't know how accurate that is. The website says 13.85"x23.93"
http://www.wheelersoffroad.com/05upometaco.htm (toward bottom)
But I can go outside tomorrow and double check
Sublime 03-12-2012 11:35 PM
Don't think the leafs compress that much? So only about 8" of travel really!
MJonAgs32 04-09-2012 11:05 AM
revisiting this thread
so I'm installing the expos in a few weeks. are the OME N182s ok?
The OMEs are 13.85"x23.93" according to Wheelers and Sierra Expeditions (listed in mm)
http://www.sierraexpeditions.com/ind..._detail&p=1432
This guy says you need them to be 27" and not 24"
http://www.tacomaworld.com/forum/2nd...ml#post4478688
but there other inaccurate information in there so idk how to read it
2011TacoSport4x4 04-19-2012 06:38 AM
I think 27" might be accurate. I have the toytec aal, getting the allpro standards soon. My truck's rear flex is limited by my ome shocks, If i disconnect the shocks I get about 2" more flex. I'm looking for a shock that allows 2 inches more travel than my current ome n182's.
