Do I need any other parts for my lift??
Discussion in 'Suspension' started by 98tacoWA, Mar 16, 2012.
  1. Mar 16, 2012 at 12:39 AM
    98tacoWA
    98tacoWA [OP] Member
    Western Washington
    97 xcab 2.7l 4wd
    So i got wheeler's 5 leaf pack, bilstein 5100s front and rear, bpv relocate, extended brake line, and strut stem washer kit.
    i have a 97 excab and the front struts i got have only 3 notches (0, 1.25, 2.5) im going to reuse the stock coils and set it on 1.25. what else do i need? I want to make sure i have everything before i start installing thanks.
    Should i get new bushings for the leafs and new u-bolts?
    Also will this be level do you guys think? or should i do the top notch? (2.5)
  2. Mar 16, 2012 at 12:44 AM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Get new bushings for everything you can, might as well since you are in there.
    Get the OME coils instead of your tired toyota ones and set the billys at 1.25 for an even lift and a far better ride.
    If you use the old stock coils you need to use the 2.5 setting for an even lift.
    You are adding a larger leaf pack so a longer ubolt kit is mandatory.
  3. Mar 16, 2012 at 9:54 AM
    98tacoWA
    Western Washington
    97 xcab 2.7l 4wd
    this will be my first time installing all this kind of stuff. :eek: could you please tell me what bushings i would need? and i have the 2.7l so id still need to put it on 2.5? im going to try it with the stocks to see how i like it then if i dont ill get some OMEs. what should i use 880s 881s? i wont be putting any winch or offroad bumper on. and will a diff drop or carrier bearing drop be necessary?
  4. Mar 17, 2012 at 1:52 AM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    880's with a diff drop kit are the way to go, since you have the little motor do it on the stock height setting with the ome or 1.25 setting with stock coils.
    The bushing kits can be found on
  5. Mar 17, 2012 at 4:19 PM
    98tacoWA
    Western Washington
    97 xcab 2.7l 4wd
    Thanks a lot man. ill call wheelers on monday
