6" Fabtech with 2.5 Fox Coilovers??
Discussion in 'Suspension' started by MADtaco09, Apr 9, 2012.
  1. Apr 9, 2012 at 6:13 PM
    MADtaco09
    MADtaco09 [OP] Hawaii, Fuck Yeah!
    Pahoa, Big Island.
    Barcelona Red TRD Sports
    6" Basic Fabtech Lift Kit. 2012 Off Road Tacoma Struts (Less than 100 miles). Cab Mount Chop. K&N CAI. Borla Exhaust. BHLM w/Custom Yellow Blinker Lens & Yellow Reflector. Black LED Altezza Tail lights. Black LED Bermuda 3rd Brake Light. Yellow Tinted Fogs w/ HID 35w 3000K. Nokya Hyper Yellow DTRL Bulb. Anytime Running Fog Light Mod. DTRL Switch Mod (Stealth Mode). Hyper White LED Dome & MAP Lights. Nokya Hyper Yellow Parking Lights. 20% Tinted Windows. Viper Alarm with Remote start. Blacked Out Valance. Blacked Out Badges. Blacked Out Radiator. Relocated Horns. OEM Roof Racks. Wet Okole Seat covers. SATOSHI Grille w/ FJ 60 TOYOTA Emblem Color Matched. TRD License Plate Frame. Sleepy Eyelids Color Matched. 13" EuroStyle Antenna. Bi-xenon Morimoto Mini Stage III Kit (D2S) Retrofit w/ Morimoto 3Five 5000K Bulbs. SS Extended Brake Lines. Seat Belt Chime OFF. Wish List: N-Fab Steps. DTLT Headers. 4.88 Gears. Alcan Leaf Springs. One Piece Drive Shaft.
    I just ordered a 6" Fabtech Basic kit and i was wondering if the 2.5 Fox coilovers w/ rem reservoir will fit on the Fabtech lift.:confused:
    I've been searching but haven't seen anyone with this setup.
    Anyone with this setup, please post some pics! Thanks!:D
  2. Apr 9, 2012 at 7:27 PM
    Large
    Large Red
    Why not just do mid travel instead of a DB lift:confused:
  3. Apr 9, 2012 at 7:32 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    I doubt this will work for your application seeing as how it's a drop bracket lift and the LCA mounting points are lower than stock.
  4. Apr 9, 2012 at 7:35 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    You can but you gotta order up custom pair it'll end costing 1900 bucks just for shocks but if you got the money I guess go for it
  5. Apr 9, 2012 at 11:54 PM
    Manwithoutaplan
    ID
    you might need a longer cup at the bottom of the shock.
  6. Apr 10, 2012 at 12:03 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    '18 T4R & '06 F250
    6" lift 40s
    for de looks! :rolleyes:
    Although I do not like DB lifts, some people do like the look. :)
    But I have nothing useful to contribute to the op...
  7. Apr 10, 2012 at 10:19 AM
    Manwithoutaplan
    ID
    the 2.5 fox shock will be to short for the Drop Bracket application unless you customize the shock.
  8. Apr 10, 2012 at 1:30 PM
    MADtaco09
    Pahoa, Big Island.
    Okay, thanks for the help!:)
  9. Apr 10, 2012 at 1:31 PM
    MADtaco09
    Pahoa, Big Island.
    Would king coilovers fit?
  10. Apr 10, 2012 at 6:13 PM
    Manwithoutaplan
    ID
  11. Apr 11, 2012 at 12:44 PM
    MADtaco09
    Pahoa, Big Island.
  12. Apr 13, 2012 at 9:54 AM
    OJwerks
    OJwerks Member
    Omar J
    Venezuela
    curious, if your going with the Fabtech kit why not just get their coilover to go with it. ??
  13. Apr 13, 2012 at 10:28 AM
    Manwithoutaplan
    ID
    because for a kit that is like 3500 to 3900 K you might as well get the 6 inch with way better shocks than dirtlogic. If i was paying that much i know i wouldnt get anything but kings for the front aleast.
  14. Apr 13, 2012 at 12:09 PM
    OJwerks
    OJwerks Member
    Omar J
    Venezuela
    ok... are the KING coilovers really worth the extra $700 :confused: ...
  15. Apr 13, 2012 at 1:52 PM
    Manwithoutaplan
    ID
    yea they are race proven and they easier to rebuild. I know with Pro comp you have to send the shocks to pro comp because supposely they have special machince to do this. Alll it is rubber seals, oil and nitrogen.
    YOu could look into icon's to.
  16. Apr 13, 2012 at 4:21 PM
    MADtaco09
    Pahoa, Big Island.
    X2
  17. Apr 13, 2012 at 4:47 PM
    OJwerks
    OJwerks Member
    Omar J
    Venezuela
    Thank you for your answers and sorry to the OP for the thread jack....
    Im putting my parts list together for a Taco build im planning, and thus why im asking... we are considering the 6" Fabtech lift, along with Total Chaos control arms, I will be looking into the Icon coilovers and other options, but we might just end up going with the dirt logic coilovers and rear shocks...
  18. Apr 13, 2012 at 5:03 PM
    Manwithoutaplan
    ID
    no problem man hope you can get a killer build going :D
  19. Oct 22, 2012 at 7:49 PM
    WhyNotFab
    WhyNotFab Well-Known Member
    Ricky
    Florida
    '08 TRD Off Road
    Looking for the same information..
    If the "basic" Fabtech 6" kit works with factory coil overs, by using a spacer.. couldn't it also work with the Fox 2.5 setup, if spacers were still used?
    I realize the suggested way would be to order the custom shocks along with the Fabtech kit, but my truck already has the 2.5 Fox kit installed with ReadyLift spacers.. so I was wondering if I could leave that part as is since it's basically a 3" lift in the front to match the rear AAL.. and then just add the DB kit and the blocks it comes with but not use the spacers/AAL it comes with.
  20. Oct 23, 2012 at 12:06 PM
    WhyNotFab
    Ricky
    Florida
    '08 TRD Off Road
    Anyone? I can't find an answer anywhere :(
