time to bring her down
Discussion in 'Suspension' started by blacksheff405, Apr 24, 2012.
  1. Apr 24, 2012 at 1:30 PM
    blacksheff405
    blacksheff405 [OP] no one ever pays me in gum
    caleb
    north carolina, concord
    02 dbl v6 12' lift on 38's
    lift kit (12'), super swampers 38's, brush gard, kc's , sub, amps, high end audio equipment
    alright I've decided I'm going to bring it down some (but mostly trying to lower some for better ride quality) I talked to my dad and that seems to be the best option right now. With that being said I'm not quite sure what is causing my suspension to be so stiff. I know In the front its the spacer but I'm not quite sure what the reason for the back is.
    The plan is to remove the (what we think is a 1 1/2inch) spacer lift in the front and get custom leaf pack for the back to make up the back's difference and get rid of the god awful blocks under it. I have some pictures of the the back and a few of the front if You have any other thoughts ideas that you believe would help feel free to speak up.
  2. Apr 24, 2012 at 4:01 PM
    Bender581
    Bender581 Well-Known Member
    AL
    Arkansas
    2012 4X4 Tacoma
    Gobi roof rack. Icon coilovers, Icon tubular UCAs, FOX 2.0 rear shocks, Icon 3-leaf progressive AAL.
    12 inches of lift. That's way up there. You'll probably need new tires if you bring it down too much. But I would bring it down. Does it drive like a log truck.:)
  3. Apr 24, 2012 at 4:17 PM
    blacksheff405
    caleb
    It needs new tires which is why I plan on doing it soon. so yes I'm going to drop tire size to 36's I think maybe 35's
    and to answer your question yes it drives like I have logs as tires.
  4. Apr 24, 2012 at 4:24 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Its stiff in the back too? Doesn't look like it should be, with blocks, a fairly light pack, looks like the back should ride like a wishy-washy caddilac... Will it bounce if you hop on the rear bumper?
  5. Apr 24, 2012 at 4:28 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    I don't know what the bushing setup is like on the first gens, but that body mount looks way loose.
  6. Apr 24, 2012 at 4:48 PM
    blacksheff405
    caleb
    I didn't even notice that... probably should look into that ha
  7. Apr 24, 2012 at 4:49 PM
    blacksheff405
    caleb
    as far as I know. the front I know sucks but I'm not sure about the back I figured it was the same.
    and as far as the bumper i'll try tmro just saw that part. (also don't have a true bumper )
  8. Apr 24, 2012 at 4:53 PM
    jandrews
    '09 FourDubDee TRD OR
  9. Apr 30, 2012 at 5:57 PM
    blacksheff405
    caleb
    this may sound like a dumb question but I'm going to 35's and I think I'm gonna take all the body lift off too. (because I hate body lifts) would this piece come off and would the leafs go where the bracket is?
  10. Apr 30, 2012 at 6:00 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    What you have for a body lift
  11. Apr 30, 2012 at 6:12 PM
    jberry813
    Jason
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    From the looks of it, you have a drop bracket lift, stacked with a preload spacer, stacked with a top plate spacer, stacked with a body lift?
    For the rear it looks like a stock leaf pack with a AAL, stacked with a lift block, stacked with an extended shackle, stacked with a body lift?
    I can see why you have a crappy ride quality. The front is preloaded to hell and the rear has a flat leaf pack.
    My suggestion is to remove it all and start over.
  12. Apr 30, 2012 at 6:15 PM
    jberry813
    Jason
    Lake Tahoe
    2012 DCSB Sport
    That's an extended shackle, not a body lift. A body lift does exactly what it sounds like...it lifts the body off the frame. It physically doesn't do anything to the truck in terms of clearance except for moving the body farther away from the frame (which *can* help clear tires, but you sacrifice safety, quality, appearance, and penis size).
  13. Apr 30, 2012 at 11:14 PM
    blacksheff405
    caleb
    well my thoughts were to remove the body lift and spacer lift leaving just the fabtech lift and get a custom leaf pack for the back. would that fix the ride quality? either way it has to come down because I'm going with 35's.
  14. May 1, 2012 at 8:36 AM
    jberry813
    Jason
    Lake Tahoe
    2012 DCSB Sport
    Sounds like a good start.
    Probably time to replace the shocks while you're at it.
  15. May 1, 2012 at 8:44 AM
    blacksheff405
    caleb
    what would you suggest that won't break the bank? Cause I think those are stock as well
  16. May 1, 2012 at 9:33 AM
    jberry813
    Jason
    Lake Tahoe
    2012 DCSB Sport
    Bilstein are inexpensive and good.
    But I don't know anything about DB lifts and whether they make them for your application.
  17. May 1, 2012 at 9:45 AM
    YotaKid62
    YotaKid62 Dirty mall crawler
    Forrest
    North Dakota
    00 Tacoma TRD Sr5 5 speed
    Grey Wire Locker Mod, 3" coil spacers & custom leaf packs, 2" BL, Skyjacker rear nitro shocks, Monroe front gas shocks; 15" eclipse sub & 1400 watt visonik amp with Kenwood stereo, Billet Petals, Black Aries series Grille guard, ebay baja lights (unsure of brand)
    I have skyjacker nitros in the back. I like them so far, and they were a good price. I just couldn't find any for the front, so If you could find them, I think you would like them.
  18. May 1, 2012 at 1:41 PM
    EL TACOROJO
    BURRY
    south mills NORCAK
  19. May 1, 2012 at 2:50 PM
    blacksheff405
    caleb
    I'm not sure. He never told us but it looks like its metal:confused:
  20. May 1, 2012 at 2:51 PM
    blacksheff405
    caleb
    should I keep the 4 shock setup in the rear?
