-   -   2" lift question from newby/my plan (http://www.tacomaworld.com/forum/suspension/225240-2-lift-question-newby-my-plan.html)
lizard1 06-18-2012 06:14 PM
Numerous threads confuse me. I will try and make this clear in hopes of soliciting guidance/help.
MY TACOMA: 2008 TRD 4x4 access cab
CURRENT UPGRADES: Bilstein 5100's in front / set at 1.75"
TSB rear leaf spring installed
Tires: 265/75/16 BFG AT 10 ply
WILL THIS LIFT KIT WORK? Ready Lift kit 69-5056 ( 2" rear lift blocks
/ front steel strut extensions )
From what I've read this will lift my truck approx. 2" front and rear. I can't afford much more at this time. Also, I do not intend to increase my tire/wheel size. Is this package good for my intentions - primarily for looks. My off roading is light...nothing extreme. Any thoughts/help would be greatly appreciated. THANKS!
ace96 06-18-2012 07:13 PM
You already have billies? You do not want to stack a spacer with them. If you off road any stay away from spacers.
KPT 06-18-2012 07:15 PM
No stacko de liftos.
lizard1 06-18-2012 08:29 PM
So I gather my intentions are not going to work. Do I increase ( if wise or possible ) the settings on the front 5100's? Spacers still in the rear?
Now that I have this Tacoma build up in my head, and I'm new at this mod process, what's the best solution?
KPT 06-19-2012 06:43 AM
You can set the 5100's at 2.5, and then use a thin top plate spacer to get up to 3", but don't go above 3" total.
