-   -   Will 5100's set at .85 help clear tires? (http://www.tacomaworld.com/forum/suspension/229989-will-5100s-set-85-help-clear-tires.html)
beeesmitty 07-18-2012 07:02 AM
Hi all,
265/75/16 BFG's, MB TKO 16,8.5 wheels. Mudflaps off.
I am having some rubbing on the rear of the front fender while turning going forward and rubbing on the front of the front fender while turning in reverse.
My question for you guys is will 5100's set at .85 remedy this rubbing, or do I have to trim regardless? I don't want to trim and raise it. I don't mind doing one or the other, but not both unless it is imperative. I would only put the 5100's on only to fix the rubbing as I don't care to raise the truck.
What are you guys thoughts? raise it and see if I still need to trim, or just trim it and forget about the 5100's? Looking for 1st hand knowledge about .85 being enough for clearance. Thanks!
NetMonkey 07-18-2012 07:11 AM
ehh... its hard to say if 0.85" of lift will prevent the rubbing. but, for certain, trimming will prevent the rubbing. and trimming is cheaper than buying new shocks :)
KPT 07-18-2012 08:47 AM
Whats the backspaing of the wheels?
beeesmitty 07-18-2012 10:10 AM
Thanks for the replies guys.
4 16X8.5 6-139.7 -6MTB MB TKO- this was on my invoice
16x8.5 -6mm offset (4.5"BS) - found this online
DevL 07-18-2012 10:36 AM
Lift has zero effect in rubbing... you will still rub in compression and eventually damage something.
KPT 07-18-2012 10:45 AM
The 0.85 would likely alleviate the rubbing when not flexed.
beeesmitty 07-18-2012 10:47 AM
So trimming will keep from rubbing in compression/flexed?
http://www.irwin.com/uploads/product...-snips-817.jpg
KPT 07-18-2012 10:49 AM
That's highly dependent on how much trimming you are willing to do.
With the 265's, I wouldn't expect you to have to do much. You're just rubbing slightly because the wheels you selected stick out 2.5" more than stock.
beeesmitty 07-18-2012 10:56 AM
Thanks,
I guess I could do both. I'm just mainly concerned with premature wear/integrity of the suspension by raising it.
NetMonkey 07-19-2012 10:56 AM
Originally Posted by beeesmitty (Post 5402382)
Thanks,
there will be very little wear at 0.85" of lift. you need to get to 3 or more inches to cause wear.
DevL 07-19-2012 01:52 PM
Do not worry about wear if under 2.5" of lift.
Do worry about rubbing with new UCAs, tires 11.5" wide or wider, tires 33" tall or taller.
Clearance can be as simple as removing the mudflaps or as complicated as a cab mount chop, hammering pich weld, trimming fender metal, and heavy plastic cutting of both the flare and fender liner. Depends on your installed components.
beeesmitty 07-22-2012 11:43 AM
Thanks for all the input guys. I'm going to do a little trimming this evening and see if I can take care of it.
