-   -   another question (http://www.tacomaworld.com/forum/suspension/235465-another-question.html)
RIDDICK3 08-21-2012 01:52 AM
another question
my shocks are going bad but i dont have the money to buy everything for the lift I want. now I have a 2.5 inch spacer kit up front and the shocks im going to get are bilstein 5100 can I set these at zero to have the same ride height? or would that damage the shock?
TROKITA 08-21-2012 02:01 AM
you'll be fine just make sure they wont bottom out, usually you'll hear it if its bottoming out but i dont think that would be a problem
4Wheelin4Banger 08-21-2012 02:04 AM
If you put your stock coils on Billies set at 2.5" you would have about the same ride height you have with the 2.5" spacers. Then later you could replace the stock coils with Eibach or OME coils & set the Billies to 0" or .85" max.
RIDDICK3 08-21-2012 02:24 AM
You think the ride would be a little better if I just set the billies 2.5 and took the spacers off
KPT 08-21-2012 07:00 AM
With the billies at zero and the spacers on there, the ride would be about the same as with the billies at 2.5 and no spacers. It's just redundant to have the spacers on there because the 5100's preload the spring themselves.
RIDDICK3 08-21-2012 11:18 AM
aight thanks for the info guys
