ICON 3 Leaf Progressive AAL ordered...
Discussion in 'Suspension' started by Pegeezy, Sep 12, 2012.
  1. Sep 12, 2012 at 9:13 AM
    Pegeezy
    Pegeezy [OP] Active Member
    Roy
    Texas
    2012 PreRunner SR5
    5100s set at 1.75, Icon AAL, Spidertrax, blacked out badges
    Ordered the ICON 3 Leaf Progressive AAL yesterday from DSM. Should be here this Friday or on Monday. I'll get it installed ASAP. Currently I am running 5100s at 1.75 in the front with stock coils. I am hoping my rig will be sitting level post-install...you can see for yourself the bro lean I got going right now...
    If all goes well, next up will be some some 265s...although I may ride these factorys out until they are bald. No use in spending the money on a new set of tires if you dont NEED them....comments/thoughts are appreciated.
  2. Sep 12, 2012 at 9:36 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    I've been reading up on these too. I've been running the single Alcan AAL for the last few years and the ride is pretty stiff and kicks out when hitting bumps in the road on turns. I ended up ordering the Wheelers version of the 3 pack which is pretty much identical to Icons. In fact just put the order in about 5 minutes ago :D
    I'm going to keep my overload leaf in because I do haul some heavy loads here and there, but overall just looking for a little more stable/softer ride for daily driving.
  3. Sep 12, 2012 at 9:37 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    That looks like you gained a lot more than 1.75" up front. Could just be the angle of the picture or the camera but that really jacked the nose up quite a bit. Are you sure you used the 1.75 setting and not the 2.5 (or that the coil seat is right-side-up?
    You're going to love the Icon AAL. I've had mine in for over a year and it's holding up great and still rides like it did on day 1.
  4. Sep 12, 2012 at 9:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    That could be due to the shocks, rather the springs. What rear shocks are you running?
  5. Sep 12, 2012 at 10:01 AM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Just the stock shocks in rear. I have Icons up front (rebuilt Leepers), any suggestions to match up the rear with my front coilovers. Good ol' Bilsteins?
  6. Sep 12, 2012 at 10:13 AM
    Pegeezy
    Roy
    Texas
    2012 PreRunner SR5
    Yea bro I made sure if was at 1.75 prior to install..It's probably the angle of the photo although I did get some significant lift in the front...thanks for posting both pics like that.
  7. Sep 12, 2012 at 10:20 AM
    98tacoma27
    Ben
    Not Beech Creek
    Just did the same thing only the Tundy versions. I put them on this past Sunday. Mine was also kicking out too. It did stop that. I also noticed my upper shock mounts were loose on both sides (Billie 5100's). I'm debating on replacing them with 5150's.
    Sorry for the thread jack OP. NICE TRUCK!!!!
  8. Sep 12, 2012 at 10:20 AM
    Pugga
    Massachusetts
    Cool, just making sure. It certainly wouldn't be the first time it happened on TW! Are you leaving the overload in place with the AAL or no?
  9. Sep 12, 2012 at 10:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Icon makes a nice rear shock too.
  10. Sep 12, 2012 at 12:46 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Right on, I'll just put the 3 pack aal in and see from there. If the hopping is still there than I'll look into shocks. My current Alcan single AAL with non TSB stock leafs with stock shocks is stiff, great for tight turns on perfect smooth pavement.
  11. Sep 12, 2012 at 12:49 PM
    speedydave
    speedydave Well-Known Member
    Dave
    Hickory, Nc
    Mustang GT
    I have the Icon's along with the 5100's at 1.75. Check my gallery for pics. I like the leaf pack.
  12. Sep 12, 2012 at 1:58 PM
    Pegeezy
    Roy
    Texas
    2012 PreRunner SR5
    Well I was going to to but the dude I talked to at DSM this morning (Sonny I think) said that he wouldn't recommend running it like that even though a lot of people on here do...I wouldn't mind the extra lift but ride quality means more to me than anything...plus I don't wanna have any rake.
