my sr5 seems low to the ground
Discussion in 'Suspension' started by FERNGULLY123, Sep 20, 2012.
  1. Sep 20, 2012 at 10:14 AM
    FERNGULLY123
    FERNGULLY123 [OP] Member
    2014 Limited
    ****Is the SR5 lower to the ground than the TRD?****
    i just got a new 2012 SR5 and when I look at the other tacoma's out there, they look higher off the ground than mine. my truck is a double cab short bed and i think it looks short and fat.
    i now want it to look taller and thiner (without buying a different truck).
    I chose the SR5 because I felt it drove much smoother than the TRD.
    I got the double cab to fit my pittbull. :) shortbed - because i am use to driving a small car, & factory tow package for my camper trailer.
    i just want my truck to look meaner, cooler, and taller....what would i have to do to my truck to accomplish that without changing the smooth ride? (tires, hood scoop, suspension?)
    P.S. please be kind... when i purchased, i didn't pay much attention to the differences btw the trucks. I just wanted a blue4x4 :) however, now... i wanna pimp it out a bit.
  2. Sep 20, 2012 at 10:23 AM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    It may seem lower due to several reasons.
    Did you park beside a trd off road or sport?
    Does your truck have the tsb springs or just the 3 leaf pack?
    Could the truck you were beside be lifted?
    My sr5 seems huge compared to my brothers friends trd off road but I have a lift in mine
  3. Sep 20, 2012 at 10:26 AM
    Jareds Toyota
    Jareds Toyota Well-Known Member
    Jared
    Washington
    2008 AC TRD Sport
    Black wheels and the next size up tire will make your truck look "meaner." that's just my opinion though.
  4. Sep 20, 2012 at 10:26 AM
    4banger09
    Alex
    Nb, Canada
    Leveled
    To answer what you would have to do you make it look meaner, lift and aggressive tires would do that. I'm not an expert on coils but I have eibachs on 5100 shocks set at .85 and it feels smoother then stock. I also removed my sway bar not sure if that adds smoothness or not but it feels "cushier "
  5. Sep 20, 2012 at 10:27 AM
    tomwopat
    tomwopat Well-Known Member
    Memphis, TN
    2012 DCSB Prerunner
    I'd guess it's the tires. I believe TRDs come with 265-75-16. My SR5 came with 245-75-16.
  6. Sep 20, 2012 at 10:27 AM
    Aw9d
    Aw9d That one guy
    My 2011 TRD OR sits higher then my moms 05 SR5. Mainly due to bigger tires and the rear leaf TSB.
  7. Sep 20, 2012 at 10:27 AM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    6-lug or 5-lug?
  8. Sep 20, 2012 at 10:13 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    TRD ORs come with 265/70R16, I dont remember the sport tire size.
    Did they even make a double cab in 5 lug?
    To the op's question, I have OME 885 coils and an add a leaf, and I think it rides better than stock. More truck like, but better. And sitting on 265/75R16s I think it looks tons better than stock.
  9. Sep 20, 2012 at 10:15 PM
    nfs257
    DFW
    She gone
    :notsure:
    Edit: Yes
    v v v v v v v
  10. Sep 20, 2012 at 10:17 PM
    HIYota
    HIYota Well-Known Member
    Angel
    Las Vegas, NV originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    Stole this from another thread on TW...5 lug DC. I actually saw one in person on the road. Had to do a double take because it looked really off having a DC that low.
  11. Sep 20, 2012 at 10:30 PM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    :eek: Thats the only one I've ever seen! That looks goofy!
  12. Sep 20, 2012 at 10:37 PM
    nfs257
    DFW
    She gone
    Only one I have ever seen, but would explain why his sits lower... :rofl:
  13. Sep 20, 2012 at 10:44 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    they started make NON-prerunner double cabs in 2011, so that could be the reason op's truck sits lower
  14. Sep 20, 2012 at 10:46 PM
    joes06tacoma
    joes06tacoma Well-Known Member
    Joe
    Central Coast, CA
    06 4x4 Off Road Access Cab v6 6spd
    LEER Shell with dome lights operated with 3 way switches, aux backup lights with relay and 3 position switch, modified wiring to compass/temp display and clock to include switch that disables dimming function (poor man's DRL solution), Scan Gauge 2
    I don't think there's supposed to be a height difference.
    Just a new set of tires in a slightly bigger size, or even just the same size but more aggressive tread will make a big difference in looks.
  15. Sep 20, 2012 at 10:49 PM
    nammer
    Nam
    Bradenton, Florida
    there surely is a very noticeable height difference between a prerunner/4x4/6 lug and a non prerunner/5 lug
    but if you're talking about trd vs sr5 6 lug, then there shouldn't be one
  16. Sep 20, 2012 at 10:56 PM
    nfs257
    DFW
    She gone
    5-lug trucks sit way lower than 6-lug due to the suspension under them...
  17. Sep 21, 2012 at 2:23 AM
    4banger09
    Alex
    Nb, Canada
    Leveled
    Other then the possibility that trds come with 265 rather then 245 tires that most sr5s come with( mine came with 245)
  18. Sep 21, 2012 at 3:13 AM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    I asked the same question when I bought my SR5! It's a common feeling. I think part of it is just a "grass is greener" complex. Part of it is also the smaller tires. And part is the perspective when you're in the truck. I've seen other trucks on the road that I KNOW are the same height as mine and they look taller.
    Some perspective:
    My sr5 with the stock 245 Dunlops and steelies:
    And with 265 Hankooks, which raises it about 1/2" (alsi switched to OR wheels, no diameter difference)
    You can see in my sig that I've added some other stuff to it to make it a bit meaner, but it still doesn't look really tall. A true 3" lift and running 285 tires would really take it to the next level but I'm not up for messing with it that much while under warranty. I might eventually go up 1.75" with billy shocks but nothing extreme.
    Be confident that your truck looks taller on the road than you think it does and just enjoy it!
  19. Sep 21, 2012 at 3:14 AM
    T@co_Pr3runn3r
    T@co_Pr3runn3r XXXXXXXXXXXXXXXXXXX
    08 RC Prerunner SR5
    They even put the flares on that DC 5 lug. Didn't know the 5 luggers came with flares but guess they kinda have to they way the front bumper is on 2012s?
  20. Sep 21, 2012 at 4:14 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    265/70 vs the 245 tire size makes a visual difference. I know there isn't an actual height difference but when I bought mine it had 245's on it and I drove it a few days before they transferred my previous truck's 265's onto the new one. They definitely made it look "bigger".
