-   -   Shock Valveing (http://www.tacomaworld.com/forum/suspension/24047-shock-valveing.html)
chris4x4 01-16-2009 07:55 PM
Shock Valveing
Taconator found this site for shock valveing:
http://www.eshocks.com/bil_ORgd.asp?Manf=All#Ratings
Packman73 01-16-2009 09:24 PM
Nice find! :cool:
Delmarva 01-16-2009 09:29 PM
x2... :thumbsup:
SC4333 01-19-2009 08:12 PM
I like it! Good find Taconator/chris4x4!!
m_yota 01-21-2009 01:14 AM
this is a great fyi site.:cool:
tigerfan00 01-21-2009 01:17 AM
chris...out of curiosity...typically a springs rate is stamped on it correct?
i forget the other numbers stamped...but i noticed when boxing my SAWs up they had a 675 on them...i was under the impression they were 650lb spring rate springs...
any clue...or anyone else with some insight?
chris4x4 01-21-2009 07:55 AM
If that number was stamped on the spring, it would be its rate. If it was on the body of the shock, then Im not sure. I havent seen the dampening rates stammped on shocks in the past, but I never really looked for them.
tigerfan00 01-21-2009 09:52 AM
it was on the spring itself...i was just confused as i thought SAWs were 650lb rates...but mine DEFINATELY said 675
chris4x4 01-21-2009 10:36 AM
They come in different rateings. From 600# all the way to 700# and in some cases even more.
Downsouth Motorsports 01-24-2009 08:34 PM
Keep in mind that this is just Bilstiens table, both King and Fox use different ratings to illustrate compression and rebound valving.
chris4x4 01-24-2009 08:38 PM
Right. But it gives people a good idea. With the rates listed, they can decide what might fit their style of driveing/off roading
Downsouth Motorsports 01-24-2009 09:38 PM
Absolutely, I apologize if that came across the wrong way.... I wish they all would just find a common table and make it a universal system. It makes something that is already confusing, twice as confusing from one make to the other...
brianr 01-24-2009 09:41 PM
wow, a crash course on shocks.
great stuff!
chris4x4 01-24-2009 09:42 PM
I dont think its that confuseing. Most of the dampening rates are in Nuetons. And many of the popular shocks are valved the sme as the Bilstiens, in what I have found, anyway. But, regardless, Its a good starting point, and then if some one wants a different set up, hopefully, you guys can accomodate. ;)
Downsouth Motorsports 01-24-2009 10:35 PM
Most of the performance rebuildable shocks are typically rated upon what shim stacks they are using for compression and rebound. Allot of the stacks are made specific to the application for slow and high speed dampening. A shocks characteristics are a result of the amount of fluid that it lets pass through its piston. On the top and bottom of the piston there are shims- ranging in size and thickness. The easier the shock oil passes by the piston the faster the shaft speed resulting in a "soft" shock. The shims are made to flex to allow the fluid to pass, the shims are arranged in a descending pattern so the lower in the stack you go the harder it is to flex. Trail and error is what it really comes down to along with experience- knowing what shim configurations do what to the characteristics of the shock. The piston itself also plays a big role in the performance of the shock as well, there are different pistons with
different styles of bleed holes.
For this reason alone is why it is so important to know your getting when purchasing a aftermarket performance shock. Not all vehicles need the same valve stacks, so there is not a "universal" valve stack that will work for all vehicles. All performance racing shocks are built to order, meaning that they do not build the shock until the valving is specified. Many Off Road retail stores like to have a large inventory of these shocks because they are popular, but many of them order "popular" valving configurations. So Joe Blow comes in off the street and wants 4 reservoir shocks for the front of his F-250. John C. Counter guy himself is unfamiliar with valving and goes to his inventory and gets the right size and travel and away Joe Blow goes....... He installs the shocks on the front of his F-250 and thinks that he got the right shocks for his specific truck, meanwhile he received a
"popular" valving that was more suited for single shock application on the front of a torsion beam VW.
It's there job to ask the questions necessary to give you the customer a
"quality sale". Never settle for whats in stock! Demand the proper valving for your vehicle, the best way to do this is have them special ordered. The same goes for bolt on coil over kits- Not all Tacoma's are the same, some are single cab, extra cab, double cab- have a winch, winch with bumper, prerunner bar with lights........ the list is endless. The point is that all of these differences add weight to the vehicle, therefore changing the way the shock preforms. Allot of people do not realize what a difference a properly valved shock can do to a trucks ride. Take for example the Off Road Trophy Trucks- they can do over a 100mph over the nastiest terrain out there! They all have different weights and suspensions that have been properly tuned or preped allowing them maximize there performance...
If you have a aftermarket performance shock or coil over get the full potential out of your suspension! Find out what valving or shim stack you have and find out if it is in fact what you need...!
Seagrave 06-17-2009 12:09 PM
I have heard that some coilovers have different types of valving. Apparently some have "linear" or "digressive" valving. It sounds like digressive is the better of the two. Do all aftermarket CO's have digressive valving?
KraQr 06-17-2009 12:14 PM
I know on my Camburg setup I went with a firm valving setup like the Tundras due to the fact that I will be running a Heavier winch bumper.
chris4x4 06-17-2009 08:09 PM
No. As far as I know, Icon is a digressive valving. I prefer a linear valveing, but alot of it depends on the off roading you do.
TacomaTSP4 04-07-2010 09:38 AM
Im going to be having 6" lift in the front and 5" in the rear and want to which 5150's i should purchase. Anyone know?
Downsouth Motorsports 04-07-2010 06:29 PM
5150's will only come in a few different valving options off of the shelf...
The 5150's in the rear would most likely be a 255/70 valving and they also have a
stem conversion kit the 5150 as well for the 05-10 Tacoma upper factory shock mount...
