2013 Leveling Kits Out?
Discussion in 'Suspension' started by Tmbrooks, Oct 22, 2012.
  1. Oct 22, 2012 at 7:24 PM
    Tmbrooks
    Tmbrooks [OP] New Member
    2013 TRD Sport
    Anyone know of any 2013 leveling kits out? Just trying to level the front 2 inches or so.
    Les Schwab claimed that no one has released leveling kits for the 2013's yet...
    This is for my 2013 Double Cab Tacoma TRD Sport
  2. Oct 22, 2012 at 7:25 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    Welcome to TW :wave:
    2013 is identical to 2005+ Tacomas (suspension wise), so any lift or level kit will do for an 05+ Tacoma (6 lug).
  3. Oct 22, 2012 at 7:35 PM
    Tmbrooks
    2013 TRD Sport
    Good to know! Any recommendations on brand for a 2 inch level kit?
    Also, with a 2 inch leveling kit up front, will I be able to fit 285/70/17's all around?
  4. Oct 22, 2012 at 7:37 PM
    Delmarva
    Tucson, AZ
  5. Oct 28, 2012 at 3:06 AM
    Tmbrooks
    2013 TRD Sport
    just ordered a pair, thanks for the info, really helped out.
  6. Feb 11, 2014 at 10:19 PM
    Nephree
    Nephree Well-Known Member
    Jeff
    SoCal
    2021 TRD OR 4x4 DCSB
    If the Billstein 5100's are set at 1.75" up front, what (if anything) needs to happen in the rear, even if leveling is the goal? I've heard that an AAL is still preferred, no?
    I have the same goal as the OP.
  7. Feb 12, 2014 at 8:26 AM
    JRod4928
    JRod4928 Well-Known Member
    Pittsburgh
    '12 Tacoma SR5
    Extang Trifecta Tonneau WeatherTech Floor Liners Pop & Lock Tailgate Lock Antenna X Black Mesh Grillcraft with Tacoma Badge (Upper) and Cross (Lower) 18" BMF Wheels / Cooper 31.5" Tires 2" Leveling Kit
    EDIT::: Just realized someone else bumped this thread and it's like 2 years old.... I'll leave the info here for future reference incase anyone cares
    You'll have to do some trimming. That's a 32.7" tall tire
    The wheel backspacing plays a huge part in this as well. Depending on what your backspacing is, you'll have to make sure your tire doesn't hit the UCA, but 285's probably won't hit the UCA with stock tires (or after market tires, since most people buy wheels to push the tire outside of the fender, which helps the UCA interference issue) from what I've read on here... But if your backspacing is too small, you'll probably be hitting your fenders, hence the trimming.
    For reference, I have 5" backspacing with 265/65/18 (31.5" tire) and I had to remove the little flap on the front bumper, because it was rubbing.
    Your alignment will move the tire forward/backward as well, which will affect things a lot.
