-   -   SKID FOR RCD LIFT?? (http://www.tacomaworld.com/forum/suspension/248170-skid-rcd-lift.html)
SemperFiTacoma 11-11-2012 02:54 AM
SKID FOR RCD LIFT??
Does anybody kno if a pro comp skid or the universal RCD skid plate will work with the RCD lift? does one skid plate fit all drop bracket lifts? i need a skid plate!!!
BulletToothTony 11-11-2012 03:36 AM
Look up metalmiller I know he has made a few
Chad7088 11-11-2012 05:15 AM
I just used my stock one.
SemperFiTacoma 11-11-2012 11:26 PM
the TRD one? mine didnt come with one but i cud buy one if its cheaper than any of te others that work. it matched up and everything?
Blacktacoma23 11-11-2012 11:30 PM
A skid that goes under the bracket, or before like factory?
SemperFiTacoma 11-11-2012 11:41 PM
if im not mistaken (havent bought it yet), the RCD comes with a skid for under the diff. so i just need one that goes to the bracket. just so im not catchin ruts and stuff with the bracket
SemperFiTacoma 11-11-2012 11:45 PM
will any skid, ie. pro comp, budbuilt, trd work with any drop bracket lift?
Blacktacoma23 11-12-2012 01:01 AM
Ive only seen TRD skids fit with DB, or custom that stops where the bracket starts
Chad7088 11-12-2012 05:18 PM
sorry for the slow response, but it is the factory skid, not trd. I don't know if it is something that would serve the purpose for what you want it for, but it bolts up with the two front bolts and the rear rests against the rcd subframe. Its definitely tight enough for every day use and possibly some light off-roading . Heavy off roading may bend it all to crap :notsure:
SemperFiTacoma 11-14-2012 05:19 AM
thanks i may have to do that. no one knows if the pro comp or universal rcd skid fits?
SemperFiTacoma 11-17-2012 07:24 AM
Chad7088 can u post a couple pics of how ur skid looks and works? itd be much appreciated!
Chad7088 11-17-2012 10:22 PM
Yes, I can do that for you. Its too dark now, but I will do it tomorrow if I get a chance.
Chad7088 11-18-2012 04:26 PM
without
http://www.tacomaworld.com/forum/att...1&d=1353283922
with skid factory skid
used the front two bolts
didn't bolt the rear of the skid. It sits flush and tight against the subframe
http://www.tacomaworld.com/forum/att...1&d=1353283979
SemperFiTacoma 11-19-2012 07:49 PM
:O none of ur pics showed up?? just little red x's.
Chad7088 11-20-2012 05:27 AM
not sure what happened..they were there:notsure:
Chad7088 11-20-2012 05:34 AM
7 Attachment(s)
Attachment 180848
Attachment 180849
Attachment 180850
Attachment 180851
Attachment 180852
Attachment 180853
Attachment 180854
