-   -   What rear 5100's?? (http://www.tacomaworld.com/forum/suspension/248438-what-rear-5100s.html)
NiceTaco 11-12-2012 05:32 PM
What rear 5100's??
I have searched...
I have asked Toytec.... She seemed very unsure.....
I am getting confused info about what rear 5100's I need.
The kit I am looking at buy is the Toytec BK0510 it comes with the standard length rear 5100's (C476)
DSM sites says with the 5100's if you have the 4 leaf pack you may need the extended shocks B110.
I have the 4 leaf pack and if I add the AAL from this kit do I require the extended shocks?
I also hate that toytec cant throw in new Ubolts in this kit and can in the one with pre assembled shocks... throw in the Ubolts guys WTF!
YotaDan 11-13-2012 10:51 AM
Not sure what kit that is exactly, but with 1.5-2" of lift in the rear the C476 5100s are the appropriate shock to use. Some people do use the longer B110, but the bump stops need to be modified so that you don't bottom out the shock and ruin it.
Normally a Single Leaf style AAL does not need longer u-bolts.
NiceTaco 11-13-2012 10:55 AM
Thanks for the reply... As for the ubolts from what I understand they should never be reused.. I jut think any kit they should be included. They do if you use the blocks so why not send with the AAL
YotaDan 11-13-2012 11:00 AM
The aal is only approx 3/8" thick or less usually. A block is at least 1" thick or more. Using the stock length u-bolts is not even an option with a block. As far as re-using u-bolts, well that is a personal preference.
Pugga 11-13-2012 11:04 AM
This man speaks the truth :thumbsup:
