-   -   Which OME Springs (885s or 886s)? (http://www.tacomaworld.com/forum/suspension/249945-ome-springs-885s-886s.html)
NumNutz 11-22-2012 09:36 AM
Which OME Springs are best for the setup below?
07 Access Cab
BruteForce Hybrid Front Bumper
9500lb Superwinch
I'm looking for about 2" of lift. I don't want driveline vibs and I don't want to have to buy UCAs. I also want to be able to use the 5100s I have on my truck now.
Thanks everyone!
OZ-T 11-22-2012 09:38 AM
How much does the bumper / winch combo weigh ?
NumNutz 11-22-2012 09:39 AM
Winch is 90lbs. Not sure about the bumper.
OZ-T 11-22-2012 09:40 AM
Well , that would certainly be a deciding factor , perhaps a pm to the vendor is in order
NumNutz 11-22-2012 09:51 AM
Let's say it weighs 150-170lbs.
I know they suggest the 886s for over 200lbs of weight in the front, but I only want about 2" of lift.
OZ-T 11-22-2012 02:23 PM
Well , you could go 885's and if they don't provide enough lift you could add some 1/4" or 1/2" top plate spacers
MadToy 11-22-2012 04:12 PM
886's will give you 3+ inches, so for that alone you're choice is clear.....
mh.meier 11-22-2012 04:17 PM
Goo 885's and get spacers if it isnt enough. 886's will not give you 3+ of lift though. I have them on a DCL:B without even the factory bumper on there and barely get 3". With a bumper and winch you wont get 3" with the 886's
MadToy 11-22-2012 04:21 PM
I'm slightly over 3 with about 140 lbs on the front between winch and skids.
OZ-T 11-22-2012 04:22 PM
886 or 886x ?
886 or 886x ?
MadToy 11-22-2012 04:26 PM
Originally Posted by OZ-T (Post 6030832)
886 or 886x ?
886
mh.meier 11-22-2012 04:26 PM
Just the 886 with no weight in the front at all. No alum factory bumper, no skid plate, no plastic bumper cover.
MadToy 11-22-2012 04:31 PM
What is your hub to fender height?
mh.meier 11-22-2012 04:32 PM
cant remember off hand but ill measure in a bit.
ross123 11-22-2012 04:33 PM
886's
krimson 11-22-2012 04:35 PM
886x
MadToy 11-22-2012 04:41 PM
For what it's worth, I have zero driveline vibes - although I do have LR UCA's which really make a big difference. My vote would be to do it right and go 886 with that much weight.
OZ-T 11-22-2012 04:45 PM
I agree LR UCA's are a good way to go , I have them , but they don't factor into driveline vibrations
MadToy 11-22-2012 04:53 PM
Not vibes, but not being able to get more than zero degrees caster made freeway driving interesting. LR's make it track like stock again with 2.8 degrees. Definitely a must have IMO.
