Rear lift Dilemma...
Discussion in 'Suspension' started by 2k4Taco, Jan 5, 2013.
  1. Jan 5, 2013 at 1:29 AM
    2k4Taco
    2k4Taco [OP] IG: Swannybruh
    Swanny
    Fleming Island, Fl
    16 DC TRD Offroad 4x4
    Icon 2.5s / 2.0's / //Dakar HD Pack//CBI T3 Front/ ATH HC Rear//SPC UCAs/ Camburg LCAs// MR312s w/ 34in Yoko GeoLndrs
    Hey guys Im trying to get another inch or inch and a half out of my rear. I already have a wheelers 3 leaf installed but I have the camper shell on the back and I wanna level the truck out but keep the shell on. I was thinking about shackles, Im trying not to go with blocks.. Ive been trying to find a 1.5 inch lift shackle but I heard they put a lot of stress on the leafs which I dont want to do.. so Im stuck... would the best option be just to wait and get a whole new rear pack, which involves waiting and more money or will I be ok with shackles?..Thanks-Swanny.
  2. Jan 5, 2013 at 1:33 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    did you keep the OL leaf when you did the wheelers?
  3. Jan 5, 2013 at 1:35 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    not so low, not so slow 2006 6 lug
    stockish
    did u remove the overload or leave it in?
    maybe u can have the leaf pack re arched?
    otherwise, maybe allpro or dakars
  4. Jan 5, 2013 at 1:36 AM
    650H1
    Michael
    VA
    id just throw on a 2" single leaf AAL into the wheelers mix..
  5. Jan 5, 2013 at 1:38 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    may work but Id worry about the ride quality........hes got the wheelers which is progressive. Throwing a thick 2" may make the ride stiffer than he likes... then he may also need longer shocks also, and then again brake lines may be an issue..... can o worms, can o worms.
    even a toytec 1.5 single aal is IMHO much stiffer than a progressive.
  6. Jan 5, 2013 at 1:40 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    what about airbags?
  7. Jan 5, 2013 at 1:42 AM
    650H1
    Michael
    VA
    he wants 1.5" of lift. if he puts a 1.5" single leaf back there itll be fine. its not going to put 1.5" on top of the wheelers pack, itll add to it slightly. anything he does is going to stiffen it up some. id just put a single leaf on and save up for all pros or dakkars
  8. Jan 5, 2013 at 1:45 AM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    1" - 1 1/2" shackle lift? would not change ride and would gain a inch :notsure:
  9. Jan 5, 2013 at 1:46 AM
    650H1
    Michael
    VA
    RTFP
  10. Jan 5, 2013 at 1:46 AM
    blake5995
    Blake
    Truckee, CA
    huh? :confused:
  11. Jan 5, 2013 at 1:48 AM
    650H1
    Michael
    VA
    read OP
  12. Jan 5, 2013 at 1:49 AM
    blake5995
    Blake
    Truckee, CA
    he says "or will i be ok with shackles?" idk maybe someone can chime in but i have never heard of 1 1/2" shackles adding stress to the leafs. Now 6" lift shackles is a different story...
  13. Jan 5, 2013 at 1:58 AM
    2k4Taco
    Swanny
    Fleming Island, Fl
    Top Gun Customs make a 1.5 inch lift shackle. so the shackle is 3 inches longer then stock( I think), Ive heard that shackles put stress on leaf springs. I am running the overload I suppose I could take that out the overload leaf and throw the toytec 1.5 on. When I did my Ubolt flip I raised the shock mount up about an inch from the stock location so hopefully the length of my 5125s will be long enongh...
  14. Jan 5, 2013 at 2:01 AM
    blake5995
    Blake
    Truckee, CA
    I will have to look more on this shackle stuff i have never heard that before. and i dont think that you will get a true 1.5 more lift with the AAL.
  15. Jan 5, 2013 at 2:04 AM
    blake5995
    Blake
    Truckee, CA
    So it looks like having a lift shackle will add stress to the front of the pack but not much for only a 1.5" lift shackle.
  16. Jan 5, 2013 at 2:05 AM
    2k4Taco
    Swanny
    Fleming Island, Fl
    Im pretty sure Ive read it on here(TW) before. Im not against running a lift shackle, but with stock leafs(1st Gen) I was just trying to figure out if it was a good idea or not... The AAL would be harder to "dial" in amount of lift Im looking for and would be stiffer..
  17. Jan 5, 2013 at 2:11 AM
    blake5995
    Blake
    Truckee, CA
    Save up for a little bit and buy a 3inch lift pack from allpro :notsure:
    need to get longer brake line and shocks
  18. Jan 5, 2013 at 2:14 AM
    2k4Taco
    Swanny
    Fleming Island, Fl
    Yeah thats probably what Ill end up doing... Thanks man.
  19. Jan 5, 2013 at 2:18 AM
    blake5995
    Blake
    Truckee, CA
    shackle sounds like the easiest quick fix. but a new pack would be the best bet in the long run :D
