Biggest tire for 3 inch lift
Discussion in 'Suspension' started by 06 tacoma owner, Jan 7, 2013.
  1. Jan 7, 2013 at 5:54 PM
    06 tacoma owner
    06 tacoma owner [OP] Well-Known Member
    Will
    Madisonville, KY
    2017 SR5 4x4
    Stock...for now
    What is the biggest tire you can run and not have trouble on a 3 inch lift?
  2. Jan 7, 2013 at 5:56 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    if you dont want to trim 255/85/16, if you want to trim, well you could fit what ever....more specifically nything from 33x11.5 (285/75/16 or 285/70/17) or a 35, but you would need to work out backspacing so you dont rub on the frame, or uca
  3. Jan 7, 2013 at 6:03 PM
    Day Cowboy
    Day Cowboy Well-Known Member
    Day Cowboy
    MS
    2011 Tacoma TX TRD 4x4
    AFE Pro Dry Air Filter, Toytec Ultimate 3' Lift, LR UCAs, WeatherTech Floorliners, Wet Okole Seat Covers
    285/75/16 or 285/70/17 without trimming
  4. Jan 7, 2013 at 6:16 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    If we're talking diameter , 255/85/16 or 255/80/17
  5. Jan 7, 2013 at 6:44 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    x2 & pretty sure you're going to rub unless you do a cab chop, regardless of 3" lift (285's)
  6. Jan 7, 2013 at 6:46 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    wheel well size does not change when you lift the truck; so the largest size you can fit stock is the largest size you can fir without rubbage
  7. Jan 7, 2013 at 6:46 PM
    06 tacoma owner
    Will
    Madisonville, KY
    2017 SR5 4x4
    Stock...for now
    Thanks for the feedback.
  8. Jan 9, 2013 at 2:58 PM
    pitacoma
    pitacoma Member
    Steve
    Cleveland
    13 Super White Blacked out
    None yet
    What about on an 18 inch rim?
