Height adjustable shocks
Discussion in 'Suspension' started by Cray, Jan 8, 2013.
  1. Jan 8, 2013 at 7:27 PM
    Cray
    Cray [OP] Well-Known Member
    Cody
    Kansas
    05 Toyota Tacoma 4x4
    Currently 3" revtek lift, plan to upgrade.
    What are all the different kinds of ride height adjustable shocks out there? Billys are the only ones i know of.
  2. Jan 9, 2013 at 10:17 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 PreRunner TRD V6
    - OME suspension - Custom front/rear tube bumpers - 33x12.5r15 BFG KOs - Deckplate mod + AFE reusable filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - Pioneer stereo and new speakers + 10" sub - camper shell
    as far as affordable shocks bilsteins take the cake. but King makes some, Donahue, Icon, and Fox all make adjustable front coilovers
  3. Jan 9, 2013 at 5:35 PM
    Cray
    Cody
    Kansas
    thanks for the reply. does rancho make them?
  4. Jan 9, 2013 at 9:36 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    not so low, not so slow 2006 6 lug
    stockish
    On the fly adjustable with a spanner is 1 thing.....bilstein 5100 are only adjustable when tension is Not on the spring seat/perch and its much more work.
    If u got the coin, and want full adjustability,superior ride, custom valving and rebuilability, then shine on the 5100s and get a nice icon/king/fox/etc setup
  5. Jan 9, 2013 at 9:38 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Guess its not a word my phone can recognize......I meant a shock that's rebuildable
  6. Jan 9, 2013 at 9:43 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    wrong... these are the 5100s fully adjustable that I'm currently running from my toytec ultimate lift
    they work just fine, however I will be slowly converting to a MT setup with one of the other brands remote resi coil overs as soon as the money is there that is
  7. Jan 9, 2013 at 9:56 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Ur right I forgot about those.....on the fly adjustable yes.......ridden with them before and they rode worse than a simple 5100 + coil swap, so I didn't mention them.
    But ur right, they are adjustable.....but not rebuildable, not as smooth, and not able to be custom valved.
  8. Jan 9, 2013 at 10:06 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    And you are correct here as well. Ride feels about the same as stock on the road, but is quite a bit better off road. A good starting point for someone not entirely sure which route they want to go with their build. I knew my route, just couldn't afford what I plan on getting to at the time, but needed to upgrade so that I could tow my toy hauler out to the desert in the meantime. Will be upgrading slowly and properly from here on out.
  9. Jan 11, 2013 at 6:53 AM
    Cray
    Cody
    Kansas
    Sounds like billys are definetly the way i wanna go. I dont want a huge lift and i dont wheel. I need new shocks and a little lift so this should work.
  10. Mar 26, 2013 at 9:30 AM
    On An Island
    On An Island Assimilated
    David
    Houston-ish
    '12 Black 4x4 DC LB TRD Sport
    Bilstein 5160 reservoir rear shocks, Bilstein 5100 height-adjustable front shocks, SuperSpring SSA19 leafs, Westin bull bar, KC Apollo Pro 6" spotlights, Leer 100XQ cap, K&N air filter, AntennaX 13" Euro antenna, tailgate washers, spare tire tool guide, Console Vault, FJ silver wheel caps
    Did you ever finish your shock replacement? I'm in the same market - a leveling lift with replacement shocks.... Did you have to put a 1/4" spacer on the driver's side to fix the lean?
  11. Mar 26, 2013 at 9:36 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    If he went with the 5100's and stock coils, no shims would be required as the spring rates are different to compensate. Most if not all aftermarket coils would require the spacer. Unless it's a fully adjustable coil over then you could adjust out the lean.
  12. Mar 26, 2013 at 9:47 AM
    On An Island
    David
    Houston-ish
    Thanks Chris!
  13. Mar 26, 2013 at 9:53 AM
    Boone
    Boone, NC
    Airbags deployed
    Anytime, glad I could help.
