Factory bump stop W/dakars
Discussion in 'Suspension' started by 842ta, Jan 10, 2013.
  1. Jan 10, 2013 at 7:46 AM
    842ta
    842ta [OP] Active Member
    DFW, TEXAS
    TRD Sport
    I just put my dakars on and the factory bump stop wont fit over the center Bolt on the dakars. Are needed or a must have with the dakars?
  2. Jan 10, 2013 at 8:12 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    You should get extended bumps to keep your leafs from going into negative arch
  3. Jan 10, 2013 at 8:14 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    And also to prevent your shocks from bottoming out
  4. Jan 10, 2013 at 8:21 AM
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
    yes, you just drill the hole a bit deeper. takes about 3 seconds
  5. Jan 10, 2013 at 8:22 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Why wouldn't you just cut the excess off the centering pin? :confused:
  6. Jan 10, 2013 at 8:22 AM
    842ta
    DFW, TEXAS
    TRD Sport
    Ok that's what I was thinking thanks
  7. Jan 10, 2013 at 8:23 AM
    842ta
    DFW, TEXAS
    TRD Sport
    Were can I get the extended one at?
  8. Jan 10, 2013 at 8:24 AM
    Pugga
    Massachusetts
    Wheeler's Off Road, Super Bumps
  9. Jan 10, 2013 at 8:50 AM
    barlowrs
    Robert
    So Cal
    Cut through 1/2" of steel or drill a 1/2" deeper hole into rubber. I suppose they both will work, but I personally would (and did) chose drilling an extra half inch into rubber over grinding steel.
  10. Jan 10, 2013 at 8:53 AM
    Pugga
    Massachusetts
    I thought it was pretty common to have to cut the centering pin after an AAL or leaf pack install. The AAL I bought had really long centering pins, I had to cut almost an inch and a half off. Didn't take more than a few seconds with an angle grinder. I didn't know if I was missing something specific to the Dakars or if it was just that the centering pin was too long.
  11. Jan 10, 2013 at 8:55 AM
    barlowrs
    Robert
    So Cal
    No centering pin is just too long. If you add the overload leaf, to the Dakar, its not AS tall (I did mine later), but regardless, its MUCH easier to simply drill the already existing hole in the rubber bumpstop an extra half inch deeper than it is to grind teh pin itself.
