-   -   Old Man Emu: Questions, Answers & Pictures (http://www.tacomaworld.com/forum/suspension/258245-old-man-emu-questions-answers-pictures.html)
4Wheelin4Banger 01-15-2013 10:05 AM
Well since Dan doesn't want questions asked on his OME Gallery thread I thought I would start a Q & A thread.
If you have a question ask away and the TW Emu Gurus will answer it.
If you have OME post a pic or two & tell us what you got.
What did you put up front & what did you get?
What did you put in back & what did you get?
If you got Dakars on a 2nd Gen share your measurements with OZ http://i.cdn2.tacomaworld.com/forum/.../paperclip.gif 2nd Gen OME Dakar hub to fender measurements (http://i.cdn2.tacomaworld.com/forum/.../multipage.gif 1 2 3 ... Last Page)
Are you running trail armor & how much lift did you loose or what did you do to regain/maintain lift?
Tire & wheel specs & rub or what you did to eliminate rub.
Are you still running a sway bar?
Thanks Mike for the info.
Originally Posted by Pugga (Post 6312775)
This should help out:
http://www.cruiseroutfitters.com/tech_OME_coils.html
Spring name/Spring rate (N/mm)/Bar dia/Coil length (mm)
OME 883 / 103 / 17 / 375
OME 884 / 103 / 17 / 385
OME 885 / 103 / 17 / 395
OME 886 / 115 / 18 / 402
103 = 588 #/in
115 = 656 #/in
From the OME Bible JohnBb 1:31
Originally Posted by JonnyBb (Post 6362346)
ARB is my shepherd, I shall not be in want. Their springs make me offroad in green pastures, their lifts allow me to ford quiet waters, they restore my dignity. ARB guides me in trails of righteousness for their name’s sake. Even though I crawl through the valley of the shadow of the mall, I will fear no evil, for you are with me; your Dakars and your armor, they comfort me. You prepare a locker before me in the presence of my haters. You drain my wallet so I can barely afford oil; my cup holders are plenty. Surely goodness and other Tacomas will follow me all the days of my life, and I will dwell in the house of ARB forever.
This thread is for everyone but if you want to go to a 1st Gen only thread it's here OLD MAN EMU SETUPS ON 1st gen
http://www.tacomaworld.com/gallery/d...ndMine0020.JPG
http://www.tacomaworld.com/gallery/d...enches0003.JPG
http://www.tacomaworld.com/gallery/d...204_163450.jpg
http://www.tacomaworld.com/gallery/d...0skids0005.JPG
885s on 90000 Sport Nitros gave me 3".
Dakars gave me 3" with shell.
If you got Dakars on a 2nd Gen share your measurements with OZ 2nd Gen OME Dakar hub to fender measurements http://www.tacomaworld.com/forum/suspension/173193-2nd-gen-ome-dakar-hub-fender-measurements.html\">1 2 3 ... Last Page)
Been there done that.
I just finnished adding 1/4" top plate spacers & I'm almost where I was before adding the sliders & skids.
I was 23 3/8" DS I'm now 23 1/8".
It rides just like it did before adding the spacer, just 1/2" higher & better than it did before adding the sliders & skids.
255/85/16 BFG KM2s on 1st Gen TRDs 16"x7" with 4.5" BS. No rub & no trim.
No & it ride even better on & off road.
OZ-T 01-15-2013 10:24 AM
:cookiemonster:
la0d0g 01-15-2013 11:00 AM
I'm just here for the emu pic :popcorn:
4Wheelin4Banger 01-15-2013 11:06 AM
It does get your attention doesn't it.
Come on Matt you've got some OME post it.
Deadcrowm 01-15-2013 11:08 AM
:popcorn:
la0d0g 01-15-2013 11:20 AM
OK I'll play :D
http://www.tacomaworld.com/gallery/d.../DSC005005.jpg
My rig and an oblig shot of Pyro
884s and 5100s
TSB and 5100s
If you got Dakars on a 2nd Gen share your measurements with OZ http://i.cdn2.tacomaworld.com/forum/.../paperclip.gif 2nd Gen OME Dakar hub to fender measurements http://www.tacomaworld.com/forum/suspension/173193-2nd-gen-ome-dakar-hub-fender-measurements.html\">1 2 3 ... Last Page)
Not yet but soon, very soon
Front relentless alum bumper with winch, IFS skid, mid skid, sliders, and relentless rear steal bumper. I have a t-case skid sitting in my garage, no comments Eric :p Not sure what I lost in lift and I didn't do anything to regain lift. Soon I'm just redoing it.
265/75/16 KM2s on 16x8 w/ 4.5 BS. No rubbing.
Yep, too scurred to take it off ;)
Here are the specs center hub to bottom of fender:
DF 21.5"
DR 22.25"
PF 21.75"
PR 22.5"
OZ-T 01-15-2013 11:22 AM
I'm not moving people's measurements from this thread to the Dakar Measurement thread
Just sayin
MJM777 01-15-2013 11:24 AM
Sub'd
evanmb31 01-15-2013 02:16 PM
09 trd offroad access cab
pic coming later
885s no top plate spacer, 2 1/2" on drivers side, 2 3/4"+ on passanger side (yes i used the trim packer) hub to fender is about 23" and 23 1/4
dakars with 3rd leaf removed. Hub to fender i am half inch higher in the rear compared to the front. Based on OZ's dakars thread, removing the 3rd leaf reduced the amount of lift by 1-1.5 inches (OME says 3/4)
Nope but i will have sliders very soon! I might add top plate spacers and reinstall the third leaf in the future EDIT: bamf sliders added and no change in measurements
EDIT AGAIN: CBI front bumper and 8500lb superwich added ~200lbs, lost about 1" of lift up front and the coilovers ride a lot softer now
SCS stealth 6 wheels- 17x8.5, 4.3" backspacing, -10mm offset with 285/70/17 duratracs. Lots of rubbing, cab mount chop, flattened pinch weld, trimed bottom of fenders front and back and removed alot of plastic. I still rub a little at full lock when the suspension is flexed hard
yes, no plans to remove it yet, i hate body roll!
only other detail about my setup is SPC light racing UCAs. Caster numbers are 2.5 and 2.7
Great idea for a thread! And thanks randy for answering my OME questions months ago before i did my lift, thanks to OZ also
nj636 01-15-2013 03:50 PM
pic coming later
can't wait to see the pics of the stealth 6 wheels :popcorn:
evanmb31 01-15-2013 03:54 PM
2 Attachment(s)
All i have right now is crappy cell picks
Attachment 190249
And a little driveway flexing :cool:
Attachment 190250
la0d0g 01-15-2013 04:19 PM
Attachment 190249
Attachment 190250
Looks great.
Question - what do you still rub at full lock?
nj636 01-15-2013 04:30 PM
Attachment 190249
Attachment 190250
looks great
evanmb31 01-15-2013 04:33 PM
Originally Posted by la0d0g (Post 6280635)
Looks great.
Thanks! During normal driving no. If i try to make them rub by stuffing the front tires at full lock they do lol. I just need to cut more plastic and a little more off of the bottom of the fender in the back of the wheel well. the trimming is not very noticable unless you know what your looking for. When the front wheel is stuffed in the wheel well i have ~ 1/4" of room between the tire and the chopped cab mount
Originally Posted by nj636 (Post 6280699)
looks great
Thank you! Im very happy with my setup.
4Wheelin4Banger 01-16-2013 10:28 AM
Thanks & you're welcome.
Taco looks good Evan.
MadToy 01-16-2013 11:00 AM
886 with Nitro 90000 up front, Dakars with N182 in the rear with this pic (changed to Fox 2.0 recently).
http://i129.photobucket.com/albums/p...maBuild002.jpg
evanmb31 01-16-2013 12:27 PM
Nice truck^ that hidden winch is awesome
Sandman614 01-16-2013 12:32 PM
:rant: there's too many pics here, there is a thread for that :rant:
jk, jk
MadToy 01-16-2013 12:34 PM
jk, jk
Ha! I'm getting confused with all the different threads, and what is expected in each :confused:
