-   -   Easiest, best, cheapest 2011 DC Prerunner lift (http://www.tacomaworld.com/forum/suspension/259093-easiest-best-cheapest-2011-dc-prerunner-lift.html)
Jdd1091 01-20-2013 12:09 PM
Hey everyone, great info here.
My son is getting his mom's 2011 DC Prerunner.
We want to raise the truck 2"-3".
Street only, a few dirt roads.
What's the best / most affordable way to raise & level the truck?
So many choices it's confusing.
Want to keep the ride the same.
I had the Daystar leveling kit on my last 2 Dodge Rams without any issues.
I have a set of 18"x9" Black Rhino wheels and was looking at getting 275/65/18 tires.
Will this size tire fit ok with a 2" lift? They are +12 backspace.
KPT 01-20-2013 01:01 PM
Bilstein 5100s are your best bet for an inexpensive but still decent lift.
I have 275/65/18s on 18x9s with +10 offset, 5100s at 1.75" lift, and I had to trim to avoid rubbing.
rickmeseke 01-20-2013 01:02 PM
if its only seeing dirt roads and absolutely no major offroad and trails excessive bumps just get a spacer lift.
it will not hurt a street truck. 60 bucks, easy to install, and it gets the job done
KPT 01-20-2013 01:04 PM
The 5100s I mentioned above are only $180, will offer a better ride than spacers, and will not have any risk of damaging the ball joints or bottoming out the shocks.
Jdd1091 01-20-2013 01:10 PM
no off roading but the streets in Louisiana SUCK.
The Bilsteins are $180 but can I install them myself?
KPT 01-20-2013 01:12 PM
If you are comfortable using a spring compressor. Otherwise you can bring the assembly to a shop and they can disassemble and reassemble the coilover assembly for a small fee.
If you want to see what 275/65/18s with the 5100s at 1.75" of lift look like, click on my signature.
4Wheelin4Banger 01-20-2013 01:18 PM
Yes you can & there is even a thread or two on how to do it without a spring compressor.
Jdd1091 01-21-2013 01:56 PM
How about something like this
http://www.readylift.com/c-83-toyota...unner-225.aspx
or this
http://www.daystarweb.com/productdet...?productID=550
KPT 01-21-2013 02:13 PM
Originally Posted by Jdd1091 (Post 6312000)
Those are both spacer lifts.
Jdd1091 01-22-2013 06:23 PM
So this would be the way to go?
Or this
With the just the rear add a leaf?
KPT 01-22-2013 07:37 PM
Yep both of those are good options. The first one will ride smoother.
Jdd1091 03-28-2013 08:12 PM
Well I did it.
Daystar 2 1/2" lift
Black Rhino 18x9 - 0 offset
Cooper Discovery At 275x65x18
ZERO rubbing
Sje1124 03-28-2013 08:21 PM
Where are you located at in Louisiana?
Jdd1091 03-28-2013 08:28 PM
Mandeville
Monster Coma 03-28-2013 08:28 PM
Lol total opposite of what Keith told you
Jdd1091 03-28-2013 08:31 PM
His way may have been better but mine was cheaper.
The kit was $115.
My son and I installed it in about 2 hours.
Can't tell the difference in ride.
KPT 03-29-2013 10:29 AM
The kit was $115.
You won't be able to tell the difference in ride with a top plate spacer. I wouldn't take that thing off the road, or over any speed bumps quickly though.
Jdd1091 04-01-2013 02:12 PM
http://www.tacomaworld.com/gallery/d...MG_0586_1_.jpg
http://www.tacomaworld.com/gallery/d...MG_0594_1_.jpg
http://www.tacomaworld.com/gallery/d...MG_0596_1_.jpg
http://www.tacomaworld.com/gallery/d...MG_0592_1_.jpg
