I need help with uniball replacement
Discussion in 'Suspension' started by extrmsob293, Feb 22, 2013.
  1. Feb 22, 2013 at 7:10 PM
    extrmsob293
    extrmsob293 [OP] Well-Known Member
    I need to replace the uniball on my camburg UCA but I don't have the retaining ring plier and a press... I tried it with the plier that I bought at harbor freight and it didn't work. If anyone live around Anaheim area and has tools please help me... I'm almost done getting my suspension together
  2. Feb 22, 2013 at 7:27 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    They are easy to press out with the right tools. with that said, you should be able to bring the arms to any automotive machine shop local to your area to have them swap them out..shouldn't charge too much for it.
    I just did mine earlier in the week and took less then an hour to remove and reinstall the UCA's.
  3. Feb 22, 2013 at 9:41 PM
    extrmsob293
    i called around and they want $20 per side which is alot for me :( all i need is the snap ring plier to take the snap ring off. I can press it out with my big C-clamp at home :D. Someone let me borrow this tool please :D
  4. Feb 23, 2013 at 6:27 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    go buy one from home depot
  5. Feb 23, 2013 at 11:08 PM
    extrmsob293
    they're about 150 for the whole set haha
  6. Feb 23, 2013 at 11:27 PM
    MonkeyProof
    SoCal- SGV
    Harbor freight will have a pair for less then ten bucks...
  7. Feb 24, 2013 at 4:59 PM
    extrmsob293
    I tried that already, there was too much tension for the plier and I think the plier was bent. Someone help me out here
  8. Feb 24, 2013 at 5:08 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    A good set of pliers will run you what its going to cost for someone to just do it for you. I paid like $160 or something dumb for a matco set.
  9. Feb 24, 2013 at 5:26 PM
    MonkeyProof
    SoCal- SGV
    Go to Sears and buy a pair..you can get what you need for under twenty bucks..
  10. Feb 24, 2013 at 5:39 PM
    P9HST2
    P9HST2 Well-Known Member
    Steve
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    My snap ring pliers from Sears that I got in the mid 1980's are still going strong. I may have bent them a little bit, but I worked on a lot of Chevy 3/4 and 1 ton drivetrains. Use them correctly and carefully and they'll last a lifetime.
  11. Feb 24, 2013 at 5:55 PM
    extrmsob293
    Man I'm broke and I'm just trying to borrow some tools not actually buying the tools. I'm a college student and I don't have a lot of money :(
  12. Feb 24, 2013 at 5:56 PM
    extrmsob293
    Sears > harbor freight anyday I just don't have the money to buy it
  13. Feb 24, 2013 at 6:01 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Walk into autozone with the arms and see if they have the snap ring pliers there that you could use real quick.
  14. Feb 24, 2013 at 6:09 PM
    ntilehman
    Seth
    Charlotte, NC
    If you come up with nothing, I live in Yucca Valley. You can make the drive in another car if your truck is all apart. Not sure where you are at.
  15. Feb 24, 2013 at 6:15 PM
    extrmsob293
    Thanks but I guess it is a far drive from Anaheim to your place
  16. Feb 24, 2013 at 6:19 PM
    ntilehman
    Seth
    Charlotte, NC
    Yea you would be looking at 2 hrs.
  17. Feb 25, 2013 at 4:45 PM
    extrmsob293
    I went to Oreilly yesterday and one of the employee helped me took them out :D. Now I will sand down the arms and repaint them black since they were chrome plated
  18. Feb 25, 2013 at 4:52 PM
    MonkeyProof
    SoCal- SGV
    Chorme plated?
  19. Feb 25, 2013 at 4:58 PM
    ntilehman
    Seth
    Charlotte, NC
    Lots of sanding to get down to a good base through the chrome.
  20. Feb 25, 2013 at 5:03 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    I want to see pics of said chrome plated UCAs
