-   -   Question about 2" tapered blocks (http://www.tacomaworld.com/forum/suspension/265249-question-about-2-tapered-blocks.html)
ecjr173 02-25-2013 12:18 PM
I just temporarily installed a set of 2" tapered blocks with some 5100 billies. Which side faces back. The bigger end or the smaller end. I put them in with the bigger end facing forward but not sure if this is correct.
Pugga 02-25-2013 12:20 PM
Bigger end faces back. The angle should help tilt the input flange in the axle upward, toward the carrier bearing.
ecjr173 02-25-2013 04:20 PM
So being that I put them in backwards. Would this be contributing to my vibration at around 30 mph.
paranoid56 02-25-2013 10:46 PM
yep, that would cause some vibs.
Pugga 02-26-2013 06:34 AM
Absolutely. Your universal joints won't be happy if you put the blocks in backwards.
