leveling kit
Discussion in 'Suspension' started by kbliss05taco, Feb 27, 2013.
  1. Feb 27, 2013 at 1:42 PM
    kbliss05taco
    kbliss05taco [OP] Member
    kevin
    oregon
    05 double cab taco
    fog mod, tint, 1.5'' spacer up front and a 1.5'' ad a leaf in the rear.
    hope this is in the right forum section im a noob, i have been researching to find a small lift to clear bigger wider tires but have not found much. the 3 inch is very popular but i did not want that much lift, so what i came up with was a rough country 1.5'' spacer up front with a 1.5'' ad a leaf from wheelers offroad. I belive it gave me enough lift to clear 33s if i have a wheel with a 4'' backspacing. and the ad a leaf i recieved from wheelers was very affordable, i was able to use the factory u bolts and the kit came with new pins ill post up some pics tonight hope this is useful for someone out there
  2. Feb 27, 2013 at 8:56 PM
    kbliss05taco
    kevin
    oregon
    05 double cab taco
    this is with 265/75/16
    next is 285/33/17 goodyear duratracs [​IMG]
  3. Feb 28, 2013 at 11:58 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    In order to clear a tire that is roughly a 33, you would need to lift the front of the vehicle about 2.5-3", and the rear approx 1.5". If you are just wanting to level the truck with the rear, then you only need lift the front about 1.25"
    The Bilstein 5100s are a great way to do either lift, and are a much better option than a spacer.
  4. Feb 28, 2013 at 12:15 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    not so low, not so slow 2006 6 lug
    stockish
    If ur set on 33's than eibachs may not be enough......if u just want to level, eibachs should be good for the rated 1.6" of lift....paired with 5100s, ur looking at a good ride imho, and ur not preloading anything nor using spacers.
    Im not sure, but eibachs and 5100s set at 0.85 may get u enough to clear 33s.
    Hopefully someone knows......
  5. Feb 28, 2013 at 12:18 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I think there's a typo in the tire size ;)
  6. Mar 1, 2013 at 8:18 AM
    kbliss05taco
    kevin
    oregon
    05 double cab taco
    yea idk the actual size id like to stuff 33s under it with some trimming ;-) im gonna try for it but may have to settle for a 32
