-   -   top spacer with ebiach coils? (http://www.tacomaworld.com/forum/suspension/265844-top-spacer-ebiach-coils.html)
jslum 02-28-2013 01:41 PM
I bought a set of ebiach coils and bilsteins from a member for my 2013 currently the billies are set at .85 and the ebiachs only give 1.6 lift on the new tacomas so my question is, is there a 1/2 top spacer I can use similar to the ome setup to get a full 3" lift up front without setting the billies at 1.75 and further preloading the springs?
BORNWILDGUY 03-01-2013 03:43 AM
I don't believe it is recommended to crank the billys up to 1.75 w ebiachs but yes there is a top plate spacer you can get from toytec that should give you the extra lift. Just curious how the ebiach's ride also
