-   -   Judge my 2013 lift (http://www.tacomaworld.com/forum/suspension/266366-judge-my-2013-lift.html)
JPT 03-03-2013 03:20 PM
Judge my 2013 lift
Ok I understand there are a ton of people that post about there lifts and look for oppinions without searching, but i am posting with minor knowledge after my searches :cool: . Im looking to get a little bit of lift but not a ton, because money does not grow on trees. Im leaning towards billies set at 1.75" and a rear 1.5" toytec aal. I am not planning on buying springs at the moment. I have also read that this should sit level; which is what I am shooting for. I do not have the spring tsb because this is a 2013 and wont be able to get it any time soon. If you guys have any suggestions, criticism, or comments, I would very much appreciate it :D
JPT 03-03-2013 05:59 PM
night-time bump
BulletToothTony 03-03-2013 06:02 PM
With the billies at 1.75 and the aal you will have a slight rake. Also I notice you have a trd offroad if you use your stock coils expect a stiffer ride...
Raz4back 03-03-2013 07:28 PM
Originally Posted by JPT (Post 6530358)
night-time bump
You'll have a little rake with that setup. I'm running the same on my '12 and like it. I actually prefer the ride over stock.
http://i648.photobucket.com/albums/u...s/IMG_8434.png
JPT 03-04-2013 07:33 AM
What do you guys mean by rake? Like a slight lower in the front causing a lean? or a lean in the back like a bro lift?
jjhitchen 03-04-2013 08:31 AM
Put them at 2.5 in the front and when it settles it will be level. Your lift idea is good and the choice of parts is also good :thumbsup:
Raz4back 03-04-2013 01:07 PM
You'll be slightly higher in the rear, probably an inch or so
JPT 03-04-2013 05:23 PM
Is it really noticeable? I didn't really notice it on your build. Also, I didn't want to set them at 2.5 because i heard the infamous Tacoma rattle will start, and I don't wont to wear down the parts so quickly.
jjhitchen 03-04-2013 05:40 PM
I put mine at 2.5 with a bone stock rear end and it is almost perfectly level, I have had zero rattle, it rides better on and off road and I couldn't be happier with my 5100's. Two of my buddies with 2nd gen dc 4x4s have had the same results pure smiles:D. You really arent changing much as far as geometry goes so the wear on parts is negligible IMHO
JPT 03-04-2013 05:45 PM
hmmm, I guess that depends on the height of your back to your front for it to be leveled. Mine was about 1/2 an inch lower in the front than in the back. Yours would probably also look a little more level because you have the sport, which has the 1 extra leaf, therefore taller in the back by a little. Anyway, thanks for all the help guys. I think im going to get this setup and sort of build around like the majority of people here :D:D:D
Primo 95 03-04-2013 05:58 PM
Measure your center hub to fender on front and rear and then decide what you want to lift. 1.75" in the front should make it level. or 2.5" in the front and a 1.5" AAL in the rear will also be level.
http://www.tacomaworld.com/forum/sus...ml#post5659548
http://www.tacomaworld.com/forum/2nd...ml#post5639290
Read my write-ups...it is a much better ride than stock.
This is 1.75" in the front and 4 factory leafs in the rear
http://i1148.photobucket.com/albums/...psb591d498.jpg
JPT 03-04-2013 06:01 PM
Thanks. your truck looks great btw!
jjhitchen 03-04-2013 06:25 PM
either way, 1.75 or 2.5 you're gonna be stoked :thumbsup: congrats on the 2013 taco!
TacoDawgfan 03-04-2013 06:32 PM
Some pics and info to help you.
Mine are set at 1.75 with only the rear leaf tsb which gave about 3/4" in the rear. Looks level for the most part, sometimes I think it's a tad nose high though.
http://www.tacomaworld.com/gallery/d.../IMG_10975.JPGhttp://www.tacomaworld.com/gallery/d.../IMG_10887.JPGhttp://www.tacomaworld.com/gallery/d...IMG_108312.JPG
My truck does have the "Taco lean" so the passenger side front sits 1/4" higher and imo that side looks nose high while the drivers side looks perfectly level.
Raz4back 03-04-2013 07:11 PM
No, it's not noticeable at all. It has less rake than stock.
JPT 03-04-2013 07:24 PM
Thanks guys! I'll start with the billies and play with them from there :D
Tripps2012 03-05-2013 07:39 AM
Here's a third option as well on my 2012 with TSB rears and Billies set at .85 and 265/75/16's
http://www.tacomaworld.com/gallery/d...edium/1893.JPG
http://www.tacomaworld.com/gallery/d...edium/1905.JPG
