-   -   5100's installed - alignment specs. (http://www.tacomaworld.com/forum/suspension/268094-5100s-installed-alignment-specs.html)
NiceTaco 03-13-2013 05:08 PM
1 Attachment(s)
got 5100's installed today.. Please check out my alignment specs and let me know. If they are off let me know what and let me know what it should be and the range.
NiceTaco 03-14-2013 03:28 AM
Bump
Millertime187 03-14-2013 03:47 AM
Look good to me. Do you have UCA?
http://img.tapatalk.com/d/13/03/14/samaje5u.jpg
This is mine from Toyota it has ranges on there
NiceTaco 03-14-2013 04:58 AM
Stock UCA's... My toe seems on the high side of the specs...
Millertime187 03-14-2013 05:04 AM
Probably since they have so much caster with the stock UCA. If your tire don't rub when you turn wheels I would say your good. Should drive good with that caster. I'm surprised they got that much with stock UCA.
Millertime187 03-14-2013 05:07 AM
http://img.tapatalk.com/d/13/03/14/qy2evysa.jpg
This one is just 3 inch lift with no UCA
Edit: also drove like crap with this one. Wondering like crazy!
Large 03-14-2013 05:11 AM
I was always under the impression:
Caster: 2.5 - 3 degrees
Camber: 0 degrees
Toe: 0 degrees
NiceTaco 03-14-2013 05:27 AM
It drives perfect no wander no pulling..
NiceTaco 03-14-2013 05:29 AM
Camber: 0 degrees
Toe: 0 degrees
That's why I posted to see what the specs were and get feedback on my results..
I think those exact specs are in a perfect world.. It looks like I am within the range.
Millertime187 03-14-2013 05:30 AM
Camber: 0 degrees
Toe: 0 degrees
Yea I do believe that's what you wanna shoot for.
Large 03-14-2013 05:30 AM
Yeah the caster on your wheels are 3.7-3.8, if it's fine for you I would leave it alone.
T@co_Pr3runn3r 03-14-2013 05:35 AM
UCAs when lifting are so worth it IMO so you don't have to be marginal on any of your alignment specs.......
Millertime187 03-14-2013 05:38 AM
They made a HUGE improvement on my truck. I'm so glad I got them.
JonnyBb 03-14-2013 05:42 AM
x3
NiceTaco 03-14-2013 08:38 AM
Mine are?
Originally Posted by JonnyBb (Post 6587298)
x3
If I go any higher I will definetley get new UCA's but not for this small of a lift.
Large 03-14-2013 08:48 AM
Originally Posted by NiceTaco (Post 6587834)
Mine are?
Whoops sorry I was looking at "millertimes" sheet.
NiceTaco 03-14-2013 08:50 AM
No problem... I was just confused for a minute..
