-   -   5100 fitment questions (http://www.tacomaworld.com/forum/suspension/268341-5100-fitment-questions.html)
Mike V. 03-15-2013 08:12 AM
Ok, so I have (after reading 100's of threads) talked myself out of a "spacer" lift and am going with a 3" lift kit with Bilstein 5100 Height Adj. Coilovers
My question is I plan on running an 18" x 9" wheel, what offset/backspacing will i need and what is the largest tire size I can run with this setup? WIll I need UCA's?
Oh, I have a dbl cap 2011 Prerunner...
NiceTaco 03-15-2013 08:18 PM
You Will need UCA's anything over 2" of lift to get it aligned.
As far as offset from what I have been told -12 offset with 4.5" backspacing will give you the best room for bigger tires.. I just got
0 offset with 5" backspacing wheels and I am told I will be fine but I am only going max of 275's..
Good luck.
