-   -   Lift help TSB trying to level out truck (http://www.tacomaworld.com/forum/suspension/268694-lift-help-tsb-trying-level-out-truck.html)
CRONKED TaCo 03-17-2013 02:00 PM
Hey guys i have the rear tsb and was wondering if I should use a two inch lift block or a one inch. If i use the one inch block i will be exactly level, but if i use the two inch block i will get the rake i want. So my question is will i have to use longer brake lines with a two inch block and tsb?
Supra TT 03-17-2013 02:07 PM
Are you going to take it off roading? Why do you want to add a block? They provide horrible road manners and are bad for the springs. Why not just get a AAL?
No I wouldn't say you need longer brake lines.
CRONKED TaCo 03-17-2013 06:22 PM
Ok so a two inch add a leaf would work?
Supra TT 03-17-2013 07:11 PM
Absolutely. There might even be a 1.5" if you'd like
evanmb31 03-17-2013 07:16 PM
Yep toytec sells a 1.5" AAL for TSB leaf packs
des0011 03-17-2013 07:59 PM
I'm wanting to do a 2" leveling kit on my truck. Any issues that anyone knows of with that. I plan on using the skyjacker kit.
evanmb31 03-17-2013 08:03 PM
Go with bilstein 5100s instead of a spacer lift, check out the suspension sub forum or try searching 5100s. Spacer lifts can cause your shock to bottom out before the bumpstops stop uptravel, spacer lifts have been known to snap and bend shocks if you offroad
Justus 03-18-2013 03:01 AM
even smoother, downsouth motorsports offers the Icon progressive AAL..... 1.5" without overload, or 2" with overload.
much smoother ride than a single aal.....I am glad I had both, now I can say I have felt the difference first hand.
OldGeezer42 03-18-2013 03:29 AM
I did a 3 leaf progressive AAL, from Wheelers(no TSB) left over load in gives me a slight rake, with front setting at 1.75, I'd stay away from blocks. The ride is softer then OEM, and I can hook up my 4-wheeler trailer ,with no bro-lean
des0011 04-03-2013 09:37 AM
Thanks for the advice, any idea on what setting to use to level it out. I'm going to be putting an ARB Bull Bar on at some time so I'll probably need to go a little high to account for the sag.
Setting for 5100's that is.
