5100 vs. 5125
Discussion in 'Suspension' started by ArcticTaco, Mar 18, 2013.
  1. Mar 18, 2013 at 12:26 AM
    ArcticTaco
    ArcticTaco [OP] Member
    Alabama
    01 TRD SR5 V6 4x4
    Brush Guard & Lights. Arctic battery, oil pan and block heaters.
    I am looking at DSM package front and rear 5100s vs. front 5100 and rear 5125. Truck is stock/TRD 4x4. Shocks are destroyed from 4 years in Fairbanks Alaska, and the bobbling has finally driven me nuts.
    I'm thinking of replacing rear leafs eventually and starting down the path of making my truck awesome. So if that's the case, can I use 5100 rear w/ stock so I can upgrade later or do I have to go w/ 5125s for now?
    I don't do much off roaring since I've left AK. But I plan on returning in a few years w/ an upgraded truck.
    Any advice?
  2. Mar 18, 2013 at 1:00 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    how are bilstein's a bandaid?? :confused:
  3. Mar 18, 2013 at 1:03 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    They are the same shock. The 5100/5125/5150(discontinued) were all the same shock.
    5125s just come in more various lengths
    5150s came in other lengths and had an external hard mounted resi
    Also you need to measure. A lot of people have found that 5100s are too long for stock replacements due to how much the stock suspension was sagging out back. Then you'd have to get a shorter 5125.
    If you go for a lift you'll have to get longer rear shocks either way.
    I'd also recommend going with the nitro charger shocks if your planning on getting a full OME lift kit. The OME coils were made to go with them. Otherwise, if you just need some shocks. Go for the 5100s up front and maybe 5125s out back depending on what size out back you need.
  4. Mar 18, 2013 at 1:05 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    96' X-Cab 4x4 TRD Off Road Clusterfuck
    JVC Deck, 10" sub mountd in rear seat cubby, 2 LED off road lights mounted in grille, amber raptor style grille lights, LED rock lights, square led bed light, custom made fuse block tray, 12 blade Blue Sea fuse block, 100a marine circuit breaker, black plasti dipped full grille, tinted tail lights + third, Uniden 520 with 4' firestik, Bilstein 5100s with 620lb Eibach coils, Diff drop, Chevy 63 leaf swap, TG creeper joints, 14" triangulated biletein 5125s, 8" extended steel braided brake line, TG Rock Sliders, CBI Moab 1.0 front bumper, custom fabbed bed rack, full TRD E-Locker axle swap and matching re-gear with custom stand alone wiring circuit, 29 spline pinion flange from an 06 wishbone runner, tubbed for 35x12.5" general grabbers on Ultra type 181 wheels, crush sleeve eliminator, Mini ARB compressor, front ARB locker, garage fab aluminum front skid plate, custom built high clearence rear bumper, removable mothafuckin doors
    they aren't, ben just hates bilstein :rolleyes:
  5. Mar 18, 2013 at 1:08 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    bandaid
    bilstein shock
    CLEARLY only one of these will fit in the strut tower of a toyota tacoma. So ben, how is it a bandaid?
    Check mate :cool:
  6. Mar 18, 2013 at 1:09 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ben the OP is asking mainly about rear shocks. Pay attention.
    5100s out back are not a bandaid. You yourself are victim to poor ply sized shocks. It's all about the bump stop and flex of your rig.
    He isn't asking for a quick front lift. Just new shocks. In which case..they do the job great.
  7. Mar 18, 2013 at 1:11 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :facepalm:
    Guys...
    Don't crap up this thread. Take it to the BS thread..
    And mark..that's a 2nd gen..
  8. Mar 18, 2013 at 1:12 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :pout:
  9. Mar 18, 2013 at 1:13 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    There are literally thousands of people on this site running them. All working just fine.
    Again. He is asking for rear shock clarification.
    Please post useful relative info next time.
  10. Mar 18, 2013 at 1:14 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :ohsnap:
    it was for the sake of the argument monte. jeez:rolleyes:
    and at first it was a pic of an f 150...but i changed it so i at least had the right company
  11. Mar 18, 2013 at 1:16 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I think mine have held up pretty dam well...
  12. Mar 18, 2013 at 1:19 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Mine are damaged because I kept stock bump stops instead of larger 4-5" ones
    I created the problem. Not blistein.
    Yes I would. My front ones are doing awesome. They are a bit stiff. But that's just their valving. Are they nice top of the line shocks...no. But they cost a 6th of the price. And do a great job.
    So yes. I do think they make nice shocks. In fact ill probably run 7100 rears next.
  13. Mar 18, 2013 at 1:23 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    and thousands of people run OME too :stirthepot:
  14. Mar 18, 2013 at 1:26 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Already risen in Jon's truck. On full OME with 883s and the trimmer package...It actually rode stiffer then mine..then again..mine is way freaking heavier..
  15. Mar 18, 2013 at 1:33 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    He has a winch. So I'd bet he has still more weight then you up front. The v6 isn't that heavy.
    Doesn't sound any different then mine.
  16. Mar 18, 2013 at 1:38 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'm not over 5k lol haven't weighted it yet..we need to go to the BS thread..haha
    And I meant Jon's vs yours.
  17. Mar 18, 2013 at 4:06 AM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    I have the 5125 and I thought they are for a truck that has small lift. They are longer than the stock Billy's. I think I lost about a inch of up travel because they now compress all the way before I tuck my tire in fender well, but I bet I gained a couple inchs of down travel. I almost need longer brake lines with the 5125's. they ride great tho. I put 5100 up front and the 5125 in the rear and love them.
  18. Mar 18, 2013 at 4:09 AM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    Mine is 3800lbs
  19. Mar 18, 2013 at 7:59 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ^^^ this
    yes 5125s can come in longer sizes. Then also come shorter. All depends on what you actually buy.
  20. Mar 18, 2013 at 8:02 AM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    Yea but the DSM has only one 5125 you can pick from when you do the package deal. If you don't have a lift OP I'd go with 5100's all around. Plus you get a lot better warranty with the 5100.
