-   -   what lift kit would you use if you don't offroad? (http://www.tacomaworld.com/forum/suspension/270001-what-lift-kit-would-you-use-if-you-dont-offroad.html)
TRD4UNC 03-25-2013 03:50 PM
There is so much information out there and I am so confused. I want a comfortable ride, i don't do any offroading, just 85% highway travel. I just want a higher stance to put bigger beefier tires. Just for looks really. Trying to stay under $800.....suggestions? i have a 2013 TRD Sport double cab preRunner
Toyotacrawler 03-25-2013 04:00 PM
I personally like my 5100's set at 1.75" and the rear TSB. It sits level, rides good. That slight lift enabled me to fit 265/75R16's. I still might get the spacer to correct the taco lean but for right now I'm satisfied with it.
TRD4UNC 03-25-2013 04:13 PM
so a spacer kit? one local shop suggessted a ReadyLift SST 3" front, 2" rear lift. They do all the local toyota dealers lifts and use this kit
Large 03-25-2013 04:16 PM
Bingo, go for it..
evanmb31 03-25-2013 04:17 PM
Spacer kit would be the cheapest option, but if you are willing to spend $800 then dont do a spacer lift. At least go with bilstein 5100s with stock coils, set at 1.75" or 2.5" and a add a leaf in the rear with new shocks. The next step up would be getting aftermarket coils to go along with the 5100s
Manwithoutaplan 03-25-2013 04:17 PM
6 inch spacers in front and 6 inch blocks in the back.
evanmb31 03-25-2013 04:18 PM
Up travel for days
TRD4UNC 03-25-2013 04:18 PM
what are the pros and cons of say for example a $350 spacer kit? like the readylift....
Manwithoutaplan 03-25-2013 04:18 PM
haha
Manwithoutaplan 03-25-2013 04:19 PM
fyi op i have 3 inch rubber spacers for the coils.
https://lh6.googleusercontent.com/-R...k/PB020241.JPG
Large 03-25-2013 04:20 PM
Just do it, you can cram 285s and will be happy if you don't wheel.
evanmb31 03-25-2013 04:21 PM
Pros - cheap
Cons - crappy ride, risk damaging your shocks, blocks in the rear prematurely wear out your springs and promote axle wrap.
Honestly you might be happy with spacers, but why cheap out on parts for a brand new $25,000 + truck
redtacoma88 03-25-2013 04:26 PM
3" Rough Country Lift. Well Priced, Simple, Includes all you need, good ride, no vibrations, room for 33" tires, Clearance for offroad. This is all coming from ME, I actually own the kit and drive it every day on my 2012.
Monster Coma 03-25-2013 04:29 PM
3" body lift :rolleyes:
Manwithoutaplan 03-25-2013 04:33 PM
^ yikes :S
VirginiaBound 03-25-2013 04:34 PM
A mallcrawler 3000, which also includes Nickelback CD and flat brim hat!
Monster Coma 03-25-2013 04:35 PM
Originally Posted by Manwithoutaplan (Post 6645401)
^ yikes :S
I like the view of my frame:cool:
maxamillion2345 03-25-2013 04:39 PM
Pick up a spacer lift on here cheap from someone upgrading and run that. If you don't like it, well the money you saved on picking them up here you can then spend to re-install better parts and you'll be back to where you were. Lots of guys running spacers happily.
Tarpon24 03-25-2013 05:11 PM
awsome hows gonna give me the hat and cd ????
Manwithoutaplan 03-25-2013 05:13 PM
I can make you Compilation Cd of Nickelback's greatest hits :p
