-   -   Best 6" suspension lift (http://www.tacomaworld.com/forum/suspension/271222-best-6-suspension-lift.html)
808wildboi 04-02-2013 12:08 AM
If you have the cash, what lift would you buy? Looking for the best lift but not sure which one :confused: I like the bds coil over setup pretty smooth:cool:
The Traveler 04-02-2013 12:20 AM
I believe that is a drop bracket lift. I've never seen one on a Taco in person, but 4" blocks in the rear doesn't sound too appealing to me. And at $3300, I'd expect at least a new leaf pack. Not too sure what kind of spindles those are, but they look beefy. I wonder if they have any lift on them.
Most guys on here with 6" lifts go with Pro Comp or Fabtech.
cameronlane 04-02-2013 12:26 AM
the best would be any bracket and then get king c/o's and king resis in the rear with real leaf packs. But that would just be silly to do that. They are all pretty much the same. lots of folks here like the procomp lifts.
AaronArf 04-02-2013 12:36 AM
The two long running contenders are Fabtech and Procomp. With the BDS kit, it looks like they subsidize the cost of the Fox coil overs by skipping the AAL. If I could do it again I'd go the BDS route. That's if I even went with a 6" lift again.
Either way, the stock leaf packs suck and even with a AAL/Block combo you'll eventually want to change them out for some custom 6" lift packs. My rear is sagging after 18k miles on the stock leafs/Fabtech AAL.
808wildboi 04-02-2013 01:24 PM
Dud your setup is sick man! I'm curious, how did you fit your 35s on your truck? I know most 6 inch lifts require some trimming. Do you have a body lift on too?
Manwithoutaplan 04-02-2013 01:32 PM
if you dead set on the 6 inch i would go with DBS.
Manwithoutaplan 04-02-2013 01:34 PM
IF you do go with pro comp just get stage 1 and then get icon's for shocks.
Pugga 04-02-2013 01:46 PM
Best 6" lift you can get is hands down SAS :cool:
Manwithoutaplan 04-02-2013 01:53 PM
Very true ^ but most people just don't have 10k laying around.
808wildboi 04-02-2013 03:44 PM
Sas would w nice. It's worth the money. If you can afford it haha
Pugga 04-02-2013 04:01 PM
True but first post said "If you have the cash" :D
