-   -   Advice on setup for on/off road (http://www.tacomaworld.com/forum/suspension/271565-advice-setup-off-road.html)
iJDub 04-03-2013 09:58 PM
So I think I'm going to go with Icon coils up front and Icon shocks (no resevoir) in the rear (Stage 1) with All Pro Expo leafs. Light Racing UCAs.
Is this a good setup for 80% on road / 20% off road driving?
What other parts should I replace while I'm at it...truck already has 120K on stock suspension.
iJDub 04-06-2013 07:22 PM
bump
Konaborne 04-06-2013 07:24 PM
that's a solid setup that'll serve you well. just don't forget the small things like longer brake lines in the rear, new ubolts and you'll be good to go!
iJDub 04-06-2013 09:38 PM
If I plan on a plate bumper should I get stiffer springs to handle the weight up front?
What kind of travel should I expect out of the front and rear?
Anything to do to keep stress off CV joints/boots?
TacomaG26 04-06-2013 09:41 PM
Not to walk on your post but do you need new branke lines for a 1.5 AAL?
Konaborne 04-06-2013 10:28 PM
what #rate are the springs you're getting? 2nd gens with plate bumpers usually want 600-650#, depending on the weight up front
expos are rated at around 11" of travel, so make sure your shocks can handle the travel
up front, im not exactly sure for 2nd gen MT setups, maybe 9" or so
and there isnt much you can do to save the boots, they're consumables that will get worn with the lift; the inherent quality of the lift puts the CV's at an angle
new brakelines are always a good idea when lifting over stock. You don't want the brakeline to be your limit strap
iJDub 04-06-2013 11:21 PM
Lol. I think someone sells longer CV boots that help keep from tearing due to angle?
Dfm155 04-13-2013 10:29 AM
iJDub, you might want to look into seeing if the ICON rear shocks will work with the Expo's. Reason I bring it up is I wanted the same setup except the standards. The ICON rears are only good for lifts 0-2", and the Expos give you up to 4". Just FYI, I'm trying to figure out which rears to go with, too.
iJDub 04-13-2013 11:34 AM
I think you're right. I may go with one of the Fox springs listed on All Pro's website then.
