-   -   Fox coilover + lift block? (http://www.tacomaworld.com/forum/suspension/273914-fox-coilover-lift-block.html)
Jkohler 04-18-2013 10:08 PM
Hey all, I am looking to purchase some fox 2.0 coilovers soon and was wondering if I could have a 3 inch lift block on top of it to have a 6 inch lift? Would this cause any problems? Right now I have bilstein 5100 height adjustable shocks in combination with a lift block, toytec upper control arms, and fabtec 6 inch lift spindles. It pretty much rides like a tank :/ I have actually blown out 3 of the bilstein shocks in two different incidences. I believe this is because I have extremely low down travel on the shock, and if I jar it hard, it makes an unpleasant sound and hard hit. Any suggestions or advice? I am looking to spend around $1,000 bucks. It is my daily driver and weekend warrior. I took it down to moab this year for the safari and took it on steel bender and golden spike and did well.
JLee 04-18-2013 10:19 PM
Nope 3" is the max unless you do a drop bracket or a body lift.
NW4RUNNER 04-18-2013 10:21 PM
Im not sure what you mean by lift block. I'm not an expert on lifts but I have 5" drop bracket with strut spacers and I put on Icon coilovers. It improved my ground clearance and added some height. What are your CV's looking like right now?
Jkohler 04-18-2013 10:22 PM
Thats what I dont really understand because I have 6 inches of lift on it right now..What would be the dangers/problems with using a block on top of the coil over?
Jkohler 04-18-2013 10:25 PM
A block is a round metal 3'' puck that goes between where the coilover and bracket where the coilover bolts in on the top
Jkohler 04-18-2013 10:27 PM
And the cv's aren't terrible, they are at a little bit of an angle. I replaced them about 20,000 miles ago and have had no issues so far. I just got back from moab as well.
JLee 04-18-2013 10:29 PM
How do you have 6" lift spindles with a 4wd :confused:
YotaOverAll 04-18-2013 10:30 PM
Sounds like he has a drop bracket already...
JLee 04-18-2013 10:33 PM
He must then i guess you could stack a 3" block on the co's if in fact you do have a drop bracket.
Jkohler 04-18-2013 10:38 PM
I will post pictures of my current setup tomorrow. Heres a link to the spindles and crossmember I currently have.
http://www.carid.com/2005-toyota-tac...FQtyQgod0xUAcQ
I am pretty sure I dont have a drop bracket lift.
4WD 04-18-2013 10:38 PM
throwing a block/spacer/or whatever on the FOX's is like pouring ketchup on a Ribeye... ya just don't do it.....:notsure:
YotaOverAll 04-18-2013 10:38 PM
OP, I'd like to see pics of your front suspension. I'm very confused lol
Jkohler 04-18-2013 10:39 PM
K Pics coming in the morning
NW4RUNNER 04-18-2013 10:39 PM
Yea maybe its semantics but I don't understand if we are talking about the same thing. Can you post some pics of the truck?
YotaOverAll 04-18-2013 10:42 PM
The truck looks like it has 6" of lift with something smaller than 35s.
JLee 04-18-2013 10:42 PM
That is a drop bracket 6" lift and it rides like crap because you have the stage one you need to get stage 2 coil overs for a better ride. They get rid of that spacer you have and are the full lenght.
NW4RUNNER 04-18-2013 10:43 PM
Yes. Looks like you have a drop bracket. You can run aftermarket coilovers just fine with most of these, although I don't know anything about that kit specifically.
Jkohler 04-19-2013 06:40 AM
Pictures
5 Attachment(s)
Heres some pictures I snapped this morning of what I have.
Is this a Drop Bracket Lift? As far as I know the aftermarket mods are as follows: new cross members, after marked 6'' spindles, aftermarket upper control arms, replacement bilstein 5100 adjustable shocks on 2nd setting, 3'' spacer (was originally a 6'' spacer if you can believe it, cut down to 3") differential/3rd member drop kit, rear driveline SYE drop kit, and aftermarket sway bars. This is my first yota, I have always had jeeps with solid axles so IFS is a new thing to me and I have been learning as I have been going. I should probably clarify that when I bought the truck it had what I was told was a truck outfitters lift. I have replaced everything except the cross members.
JLee 04-19-2013 07:52 AM
That is a drop bracket lift.
Jkohler 04-19-2013 08:11 AM
Glad we figured that out haha. I am fairly new to IFS lifts. This might be a stupid question, but how does a DB lift work? Is there a way to tell how much of a DB lift I have? What would be the best coilovers to go with this DB to get a 6'' lift? Do I need to buy 6'' lift coilovers?
