-   -   Removing Wheelers 3 AAL, returning to stock? (http://www.tacomaworld.com/forum/suspension/275326-removing-wheelers-3-aal-returning-stock.html)
gunhound 04-28-2013 10:35 AM
Need to remove a Wheelers progressive 3 AAL so I can return it to stock configuration.
This is on a 2012 DCLB Sport 4x4.
Since I cut the factory brackets, would I need to come up with some type of after market brackets?
Pugga 04-28-2013 10:37 AM
Yes, you should put something back to keep the leafs in line. I can be as simple as 2 pieces of plate steel and 2 bolts. Check out what 4WD (Doug) does for leaf spring retainers on the leaf packs he builds.
