difference between OME leaf springs cso45r and cso47
Discussion in 'Suspension' started by Mudsaucecoma, Apr 30, 2013.
  1. Apr 30, 2013 at 8:47 PM
    Mudsaucecoma
    Mudsaucecoma [OP] Marks fucking mechanic
    Andy
    boise, idaho
    06 tacoma trd off road dcsb
    265/75r16 cooper discoverer st maxx ome 3" with 885 coils w/ an aal anytime locker mod sway bar delete Storm trooper mods custom hybrid sliders w/ kickout BHLM uniden 520xlpro w/ 4' firestck firewire and a B.A.M.F antenna mount
    Hello. I've seen two different kinds of leaf springs for my 06 taco and ran Into one hell of a deal on some of the cso45r springs but can not find any info on them other than that they fit the hilux. I don't mind getting the cso47's but if the 45r's will work ill use thoes. And if they will work. Is there any difference between the two. (Pros and cons)
    Thanks.
  2. Apr 30, 2013 at 8:50 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    The CSO47 springs are for the 2005-13 Tacomas , never heard of the Hilux ones fitting on a Tacoma
  3. May 1, 2013 at 4:59 AM
    Mudsaucecoma
    Andy
    boise, idaho
    I was thinking so. But there is no info out anywhere that I can find about the 45r's. I even e mailed arb and didn't get a reply back.
    I forgot to say that the 45r's are listed as 05-09 hilux/pickup
  4. May 1, 2013 at 10:04 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    CS043R:1/2" light load
    CS043R-15: 0" light load
    CS044R:1-3/4" light load
    CS045R:1-3/4" heavy constant load
    I found the above description at this link:
    http://4x4.fatbobsgarage.com/toyota-hiluxpickup-175-rear-heavy-constant-load-leaf-spring-lift-2005-2009-p8798.aspx
    Use the "next product>" & "<previous product" to scroll through the other models.
    Here's a little bit of tech info on the CS045R:
    http://www.sierraexpeditions.com/index.php?l=product_detail&p=1365
    You can search the other models if you want there, too.
  5. May 1, 2013 at 12:19 PM
    OZ-T
    Peter North
    British Columbia
    The tech info link shows 2 different eye diameters , front and back , 20 and 30mm
    Pretty certain Tacoma's are 40 mm
    http://www.sierraexpeditions.com/index.php?l=product_detail&p=1368
  6. May 1, 2013 at 1:37 PM
    splitbolt
    NW Arkansas
    I saw that; 40mm front/30mm rear. I wonder if that's a Toyota or OME thing.
    I noticed the Bob's Garage site says; "Required for Installation-(2) Spring Bushing Kit, (4) U-bolt, Greasable Shackle Kit" and "Vehicle Application:
    2005-2009 Toyota Hilux, 2005-2009 Toyota Pickup".
    I wonder if the shackle kit is required because the 30mm bushing is a OME thing.
    I emailed Bob's to see about Tacomas.
  7. May 1, 2013 at 5:33 PM
    Mudsaucecoma
    Andy
    boise, idaho
    Thanks guys!. I did find the sierra expeditions site today but did not go any further after I found the 45r's on it. ill do some more digging. and possibly talk to Bob as well.
  8. Aug 31, 2013 at 3:35 PM
    pbcolt
    pbcolt Well-Known Member
    Colton
    San Diego
    2017 Tundra DC Limited 4x4
    Bumping this. Did you find anymore information about using a set of Dakars other than the normally specified CSO47R?
    It seems like a set of leafs designed for less constant weight might be better than taking a leaf out of the CSO47R's.
  9. Sep 2, 2013 at 7:47 PM
    OZ-T
    Peter North
    British Columbia
    I thought it was established that the eyes don't jive
  10. Sep 2, 2013 at 8:27 PM
    pbcolt
    Colton
    San Diego
    Is that something that a different shackle would fix? The fronts are the same right?
  11. Sep 7, 2013 at 12:37 PM
    splitbolt
    NW Arkansas
  12. Sep 7, 2013 at 12:47 PM
    OZ-T
    Peter North
    British Columbia
  13. Sep 7, 2013 at 2:40 PM
    pbcolt
    Colton
    San Diego
    I think you're right that tacos are 40/40, but if OME has a 30mm shackle then might it work?
  14. Sep 7, 2013 at 3:16 PM
    OZ-T
    Peter North
    British Columbia
    Why are people trying so hard to make Dakars designed for a Hilux fit on a Tacoma instead of just using the Dakars designed to fit on the Tacoma
    This is my question
  15. Sep 7, 2013 at 4:35 PM
    splitbolt
    NW Arkansas
    Options;
    CS043R: 1/2" light load
    CS044R: 1-3/4" light load
    CS045R: 1-3/4" heavy constant load
    I would have liked 0-1/2".
    Tacoma offerings are taller and stiffer.
    -CS047R w/ 3rd leaf removed is 1.75" light load
    -CS047R is 2.25" medium load
    -CS047R w/ D29XL is 3" heavy load
  16. Sep 7, 2013 at 4:38 PM
    pbcolt
    Colton
    San Diego
    Bingo.
  17. Sep 7, 2013 at 5:04 PM
    OZ-T
    Peter North
    British Columbia
    Why not get the Wheelers HD leaf packs if you want minimal lift ?
  18. Sep 7, 2013 at 5:29 PM
    OZ-T
    Peter North
    British Columbia
    Besides the difference in eye diameters , has it been established that the rest of the dimensions are the same ?
    ie : eye to eye , location of centre pin ?
  19. Sep 7, 2013 at 8:58 PM
    pbcolt
    Colton
    San Diego
    To get rid of the POS Toyota leafs alltogether and not spend $6-700 on custom Alcans.
    Nope. Good points.
  20. Sep 7, 2013 at 9:14 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I don't think the wheelers leaf springs are $700. I beleive they sell the alcans which are a bit pricey. But the wheelers leaf springs come with either the 4 leafs or 5 leafs. I beleive the wheelers 4 and 5 packs are roughly $450
