-   -   Enjoying Sway A Way Racerunners (http://www.tacomaworld.com/forum/suspension/276082-enjoying-sway-way-racerunners.html)
916 YATES 05-02-2013 08:00 AM
Really noticing improved ride with my Sway A Way Racerunners after a one week break in period. Truck rides like a well tuned sports car. I failed to read the directions, mixed up the lower front shock bushings(put the longer of the two in back) had to remove the stabilizer bar. I am still debating wether I want to break it all down to flip the bushings and put the stabilizer bar back in. Will I get more articulation off road with out it? The Sway A Way kit was nice and complete(had I read the instructions). Waiting to address rear leafs to get a more plush feel out back. I am very satisfied with coil overs and shocks.:thumbsup:http://www.tacomaworld.com/gallery/d...o_pics_011.jpg
916 YATES 05-02-2013 08:11 AM
url=http://www.tacomaworld.com/gallery/showphoto.php/photo/323751/cat/500]http://www.tacomaworld.com/gallery/d...o_pics_013.jpg[/url]
916 YATES 05-02-2013 08:12 AM
http://www.tacomaworld.com/gallery/d...o_pics_010.jpg
Gearheadesw 05-03-2013 01:26 PM
SCS Stealth 6's satin silver FTW
916 YATES 05-04-2013 06:11 PM
tires and pics as soon as funds are available:D
snorola 05-04-2013 10:40 PM
I have the SAW 2.0's as well. How much lift do you have up front?
I had a huge amount of preload just to get 2.5" of lift with a bumper and ifs skid
http://www.tacomaworld.com/gallery/d...m/IMG_6172.JPG
Just rebuilt them and upgraded to new eibach coils 14" x 650lbs and have the same amount of lift but way less preload, ride super nice!
http://www.tacomaworld.com/gallery/d.../IMG_61883.JPG
916 YATES 05-05-2013 09:31 PM
got about 2" lift with stock upper control arms, need more caster to go higher, Light Racing control arms next for the front, leafs or add a leaf next out back.
916 YATES 05-05-2013 09:32 PM
how many miles to rebuild? looks great with 14" coils
snorola 05-05-2013 10:13 PM
I have rebuilt them twice now, bought them used unknown mileage and one started leaking after 20,000kms. Since then I put 60,000kms on them until I rebuilt them again last week.
We have lots of gravel/sand/salt and grime on the roads so they have a pretty hard life, you should get more miles down south on yours. I would get the nitrogen checked/charged regularly (once a year?) as it looses pressure over time.
If you end up putting steel bumper/skids on down the road I would recommend the 14" springs, they were fairly cheap from dsm and handle the extra weight well.
YotaDan 05-06-2013 02:24 PM
Are you wanting to lift the rear also, or just try to improve the ride?
BAMFTACO 05-06-2013 02:39 PM
SAW for the win I love my sway a aways.
916 YATES 05-06-2013 06:07 PM
I am looking to gain 1.5 -2" of lift and soften the ride out back. I tow a trailer with dirt bikes and gear, guessing it is 2500 lbs. with 500 lb tounge weight. Saving for Light Racing UCA's so that I continue to go up in the front(@ 2" now). O.K. with slight rake or level when done.
YotaDan 05-06-2013 06:47 PM
Best bet out back would be our 3 Leaf HD AAL Set.
916 YATES 05-06-2013 08:22 PM
gonna ride softer than stock set up? Was even thinking of softer 3 leaf -add a leaf and still run overload for towing? Which set up will give close to 1.5 for double cab long bed and soften the compression enough to be in the Sway A way's stroke enough? Or HD with out overload?
916 YATES 05-06-2013 08:26 PM
these are sweet rear shocks, not using them properly jarring off initial hit with OEM leaf springs.
YotaDan 05-08-2013 10:08 AM
Well it is hard to have both soft ride and load capacity. But, yes the HD 3 leaf with the Overload removed. Should be about 1.5" of lift.
916 YATES 05-08-2013 01:40 PM
Thanks Dan, I am gonna put these on my wish list.:D
tacoma guy 05-14-2013 05:44 PM
Yeah I had them on my 1st. gen and just loved them ! They where the old style where the rod came out of the top. I did get a squeak shortly after installing them. Did any of you guys get any squeaking out of yours? Never the less. I did love them a lot. :D
916 YATES 05-14-2013 06:34 PM
I mixed up the lower bushings(put the long one in the back) and it squeaked like crazy rubbing on sway bar. took sway bar off till I have time to swap bushings around. Hopefully that will more coil over back enough to clear sway bar.
tacoma guy 05-14-2013 06:51 PM
Oh yeah I can see how that would make a difference. Mine where squeaking from the seal around shock shaft. Because the shaft was on top I put some grease around the shaft and it was gone. Just wondering if the new style have the same problem. Thanks for your reply.
