I'm stupid. Need leaf spring 2nd gen help...
Discussion in 'Suspension' started by KalamaKid, May 26, 2013.
  1. May 26, 2013 at 9:03 PM
    KalamaKid
    KalamaKid [OP] Well-Known Member
    Jason
    Oregon
    same shit as everyone else
    I bought a pair of brand new leaf springs off a 2012. I added a wheelers 3 leaf progressive pack to the springs and installed them today. Ride is amazing and fixed the problem of my shot 5 yeah old leafs. But now my alignment is off... Not sure how though?
    The center pins are in the proper center hole on the axle, I put weight on the springs and tightened down the rear hangar like I believe i was supposed to. Basically my rear axle is 1/4 an inch maybe a bit less fwd on one side than the other? Steering wheel is slightly cocked down to the left side while driving on the freeway. Braking or not its still off a bit and pulls to the right.
    The overload spring has a tapped hole for the e-brake mount. On the springs i picked up on craigslist the tapped hole was on the left side on both springs. Although I was under the impression that the springs for a 05+ are the same length so I wasn't worried... The ebrake now mounts to my wheelers pack so it wasn't an issue.
    Are the 05+ springs the same length? Do i need to swap them if not? Did I just buy two left side springs from this fucker? FML, went from an easy $200 brand new leaf pack into a mess. Any help is welcome. No derp just help ;)
  2. May 26, 2013 at 9:14 PM
    taco terror
    taco terror 1st gen = best gen
    North Carolina
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    You didn't put one of the leaf packs back on in the wrong direction did you? Measure to find out and please don't drive it like that.
  3. May 26, 2013 at 9:16 PM
    KalamaKid
    Jason
    Oregon
    No... The second leaf that hangs down a bit is facing FWD on both sides. Checked that five times ;)
    Not driving it at all until I fix said issue btw
  4. May 26, 2013 at 9:19 PM
    taco terror
    North Carolina
    Hmmm, I hope someone on here will help, Id jack the sucker up and remove the rear wheels and inspect every single thing spring related. You may have already done that though....
  5. May 26, 2013 at 9:26 PM
    KalamaKid
    Jason
    Oregon
    Indeed lol i'm stumped
  6. May 26, 2013 at 9:51 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Sorry to hear about your problem jason.. Its odd that your front end allignment would be off. As for your rear axle being off. I believe mine was the same way. One side was a hair more foward then the other. But after i got my allignment done it drove great! I havent checked it since then... i could check to see if the axle is still off tomorrow if youde like. but Im glad you like the progressive AAL.
  7. May 26, 2013 at 9:58 PM
    KalamaKid
    Jason
    Oregon
    Well I don't think the front end is off at all... I check out the eccentrics and nothing moved. I think the rear is just tracking closer on one side than the other...
  8. May 26, 2013 at 10:13 PM
    ETaco23
    Evan
    PNW
    Makes sense.. So you driver's side foward about a 1/4"... Ill check mine tomorrow bc i have the exact same setup and leaf packs.
  9. May 26, 2013 at 10:16 PM
    KalamaKid
    Jason
    Oregon
    No passenger side is 1/4 more fwd
  10. May 26, 2013 at 10:18 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Can the shackles move freely ?
  11. May 26, 2013 at 10:25 PM
    KalamaKid
    Jason
    Oregon
    What do you mean "move freely". I can move one more fwd than the other but the default position is straight up and down. It's pretty thin metal there. I see where you are going and it's the same way I'm thinkin but why would one need to be further fwd than the other and which one should I move fwd?
  12. May 26, 2013 at 10:27 PM
    OZ-T
    Peter North
    British Columbia
    I mean can they move when you flex the springs up and down
  13. May 26, 2013 at 10:41 PM
    KalamaKid
    Jason
    Oregon
    Exactly and I've moved them about but I can figure out which one to move more FWD than the other. Which one do you have moved more fwd? My stock leaves had them set at an equal angle.
  14. May 26, 2013 at 10:42 PM
    OZ-T
    Peter North
    British Columbia
    I'm not following you , I was just wondering if one was stiff and not returning to a "neutral" postion
  15. May 26, 2013 at 10:50 PM
    KalamaKid
    Jason
    Oregon
    No they are both returning to neutral. Which is why I'm lost too
  16. May 26, 2013 at 10:53 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    I hate to tell ya, but it's Dis-n-Ass time ha
  17. May 26, 2013 at 10:54 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Take it apart again and compare the packs side by side.
    Confirm the locating pin wasn't improperly drilled.
    The change in height in the rear will impact caster, but not seriously.
  18. May 26, 2013 at 11:04 PM
    KalamaKid
    Jason
    Oregon
    They measured the exact same. I only lost about a 1/2 inch of lift in the rear. I don't think that would fuck with the caster as much as I'm feeling.
  19. May 26, 2013 at 11:15 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    No, what you're feeling is the result of the axle not tracking straight.
    Caster is the tendency of the front wheels to want to return to center... like a shopping cart caster is always (hopefully) in the right direction even without a steering wheel.
    No.. 1/2" gain or loss, you wouldn't feel that in the alignment.
  20. May 26, 2013 at 11:25 PM
    KalamaKid
    Jason
    Oregon
    Exactly so why is the damn axle not tracking straight?! I understand caster and thanks for the imput :thumbsup: :)
